Manual RAck in an EG???
prob is tryin to find them ive tried finding a match nothing i can get the rack but not the subframe how much is it from a junkyard over here in the NE i still havent been able to find one
i put a manual rack on my eg, it had PS. it bolted right on. got an alignment and im good to go. not too complicated
subframes are the same. dont make it more then it is and confuse people
Time to end this.
manual steering - subframe p/n 50200-SR3-C00
power steering - subframe p/n 50200-SR3-H50
You can see the mount on the passenger side is flat.
Manual mount bushing looks like a swaybar bushing.
Power is circle. Similar to this blue one.
The proper to do a manual steering swap/conversion is the use the manual subframe.
Other option is custom bracket and/or bushing.
The bushings are different because a power rack is like twice the size of a manual rack however the mounting points remain the same.
just buy the energy suspension power rack bushing it goes over the manual bushing, as in double them up.. perfect fit, use a blade to round off the corrners of the manual bushing to prevent play.
