K24A2 into 02 Type-S
My son dropped 2 valves in his Type-S so we are going to swap a K24A2 out of an 05 TSX.
I just wanted to see if anyone thinks I have left anything out for this swap.
Motor K24A2 = salvage yard
Kpro with Hondata's oem TSX reflash program installed = Hondata
Clutch = Exedy stage 1
adapter for t-body = OBX
Header = OBX
motor mount inserts = ES
New upper TSX rad hose
new lower RSX hose
CR-V front cover mount = Honda
Possible a cat-back if funds permit.
Is there anything else that would be suggested to get & install at the same time.
This is a DD & he just wants to car to be alittle stronger sense hes having to shell out the cash to replace the motor.
We will have the block for sale shortly if any one is interested. I don't know if the head is reuseable 2 of the valves are turned side ways & imbedded in the head.
TIA
Header = OBX
new lower RSX hose
TIA
header wont fit. It'll need to be modified. Also you don't need a TSX hose you reuse the RSX one. Or buy the gates hose off of CRSX designed for the Injen CAI.
Which Intake manifold is he planning on running and what intake?
If the k20a2 is fixable, and you don't want it... pass it my way. I will buy it from you.
I want to do the k20 head on my k24 block..(poor-man's TSX) the hybrid mod is very nice... and puts up great numbers.
Keep me posted.
Plz. Kthx.
Keep me posted.
Plz. Kthx.
We have a Kiddracing header on on the way. I read on CRSX that you can use a TSX upper hose & cut the RSX lower hose to fit. He has a Injen short ram on the car already. I am not gonna buy the hoses till the motor is sitting in the car.
I'm using my OEM RSX hoses upper and lower. What do I know though... never done the k24 swap lol. And I didn't cut any hoses. But I used the RSX thermostat housing
The only other tricky one I'll give you advice on is the Knock sensor... all of the threads I read said to reuse the K20 knock sensor on the k24... but I kept getting CEL for knock sensor malfunction.. so I soldered on the k24 knock sensor harness plug and used a k24 knock sensor and bam no more CEL.
I think I read your post about keeping the stock K24 knock sensor & I am going to keep that in mind also.
I just wish the motor will get here so we can start.
black99x
Sep 27, 2006 04:18 PM
mustninty
Aug 22, 2004 07:09 AM
