Will a bad VTEC solenoid throw a CEL?
Old Mar 4, 2010 | 05:22 AM
wreckedmyteg's Avatar
Icon2 Will a bad VTEC solenoid throw a CEL?
97 GSR I recently picked up.
Consistently getting 19-21 mpg, with a mix of city / highway (predominately highway) driving.
Things I've done -
Checked air filter - looks new
Replaced plugs - didn't look too bad, but #2 was a little white
Replaced fuel filter - last night. Not sure if this will make a difference or not
New symptom to add -
Sometimes (it's happened 4-5 times) when I hit between 4-5k while slowely accelerating (not floored, but giving it some) it has what feels like a hole in the fuel map.
I doubt it's a misfire since it's fine at all other RPMs.
I'm thinking the VTEC solenoid is sticking. Would that throw a CEL?
Old Mar 4, 2010 | 12:03 PM
racebum's Avatar
Default Re: Will a bad VTEC solenoid throw a CEL?
check the ignition timing. the low mpg here is what's making me think elsewhere. a vtec solenoid oddly won't always throw a cel when it fails. the thing is, your mpg statements point somewhere else. out of vtec you should be getting around 300 miles per tank with a stock gsr
GSR coupe
Feb 27, 2010 12:11 PM
BoostedGSREJ1
14
Nov 18, 2009 06:00 AM
snorkelking
Feb 5, 2007 09:17 PM
roc
Sep 10, 2006 07:49 AM
t_lager
Jul 17, 2005 10:38 AM
