Brake lights staying on
Old Mar 4, 2010 | 05:08 AM
MrExclusive's Avatar
Default Brake lights staying on
I heard this is a common issue with Hondas. When I step on the brakes sometimes it will stay on for a long period of time or sometimes even forever unless I literally use my hands to pull on it a little. However when im pulling on it. Its not as if its stucked which I find weird.
Any suggestions on how to fix this issue???
Old Mar 4, 2010 | 05:13 AM
Luis.'s Avatar
Default Re: Brake lights staying on
Look at the brake pedal itself, follow the lever upwards and you'll see a pin-sensor mechanism, if you get a 10 or 12 open end you can adjust it forward or backward to make sure it's making adequate pressure with the lever itself.
Basically it's too far away from the lever, so it's taking a while for the lever to press back into it which turns off your lights. It's common with Civics.
Old Mar 4, 2010 | 05:25 AM
Read/Followed/Experimented/Fixed!!!...Well at least for now lol.
Thank you
Old Mar 4, 2010 | 05:31 AM
Luis.'s Avatar
Thank you
It's a done deal, you won't have any further issues as long as the contact is almost instant, and I'm sure you adjusted it to that point.
You're welcome, here's one of these
Projekt_2nr
Jul 31, 2006 09:06 AM
Agent Daimon
11
Jul 19, 2002 08:39 PM
acuraLSSE95
10
Jan 27, 2002 05:50 PM
acuraLSSE95
Jan 27, 2002 01:16 PM
