shock mod...is this a good idea?
Old Sep 7, 2002 | 07:00 PM
tinkfist's Avatar
Default shock mod...is this a good idea?
listen to this and tell me what you all think:
the end of the rear itr and civic shocks are simply comprised of a mounting piece welded to the rest of the shock. i should note that the weld is only a small .5" weld on either side of the mounting piece. my idea is to saw off the ends of the itr and civic shocks and weld the civic forks onto the end of the itr shocks. the weld should be fairly simple. does anyone know the anatomy of a shock well enough to know if i would be doing any internal damage to the hydraulics of the shock?
please post what you think of this or if you have heard any other stories of how to fit the itr's to a 6th gen civic.
tinkfist.
Old Sep 7, 2002 | 07:51 PM
kikicamacho's Avatar
Default Re: shock mod...is this a good idea? (tinkfist)
The only issue I see is the quality of the weld. It better be strong. Other than that you should be fine.
Freeltec
May 11, 2005 03:26 PM
RiceRocket
Oct 10, 2001 08:25 PM
