idle problem, can't find the answer
Old Mar 4, 2010 | 04:46 AM
rhdej2's Avatar
Default idle problem, can't find the answer
97 ek hatch with a b18c1, skunk2 IM, b17a cams, JE 9:1 pistons, eagle rods, those are the only mods i do believe. oh and there's still a catch can and the oil pan is still tapped from where it had a turbo. but here's my problem, my car, at all times, idles at around 250 rpm's. when i start it in the morning, i have to keep my foot on the gas to keep it from dying for like 15 minutes. the idle never surges, it is always like that. idk what the problem is. and i don't think i have a vaccuum line loose or disconnected, but that's the only problem that i can think of that would cause this?
Old Mar 4, 2010 | 05:02 AM
97twodoor's Avatar
Default Re: idle problem, can't find the answer
Check to see if the IACV is working. Make sure its not carboned up.
Old Mar 4, 2010 | 06:13 AM
rhdej2's Avatar
well the little screw is seized up, could that possibly be it?
Old Mar 4, 2010 | 06:48 AM
97twodoor's Avatar
Are you talking about inside the IACV? If it is seized then your idle will not be correct.
longshot
Nov 30, 2008 10:44 AM
samdizzle562
May 30, 2007 12:21 PM
matt j
Jan 2, 2004 07:21 AM
