Noob Q: D16y8 valve cover
Old Mar 4, 2010 | 04:03 AM
runnamukk's Avatar
Default Noob Q: D16y8 valve cover
Haven't been able to find this in a dedicated thread crawl, sorry.
Scored a '99 Y8 cheap, which of course means missing bits.
Are valve covers unique or which head covers will work? TIA. H-T rocks!
Old Mar 4, 2010 | 05:03 AM
dephtone's Avatar
Default Re: Noob Q: D16y8 valve cover
The valve cover you use on the y8 must be a valve cover from a SOHC VTEC as the spark plug location differ from VTEC and non VTEC.
VTEC valve covers have the spark plug holes towards the front of the engine.
Non-VTEC is just the opposite. The plug holes are toward the back of the motor.
Old Mar 4, 2010 | 05:16 AM
Special_Ed's Avatar
New User
haha there you go your question is answered
Old Mar 4, 2010 | 06:52 AM
jlicrx's Avatar
not exactly true - the D16Y7 (non-VTEC) valve cover has spark plug holes on the front and will fit the D16Y8 (D16Y5 VTEC-E will also work)
this is a D16Y7:
Old Mar 4, 2010 | 09:11 AM
B18B1-Crx's Avatar
this is a D16Y7:
[/QUOTE]
notice the shock by cam gear?
What are these called?
Can you get the to work on a shell with a engine swap?
Old Mar 4, 2010 | 09:50 AM
EFRue57's Avatar
that is an engine torque damper
Old Mar 4, 2010 | 09:58 AM
EFRue57's Avatar
no one makes these for the EF chassis, however you can modify the EK engine damper to fit the EF chassis with a d series engine. i do not know if it will work with the b series swap.
robs97
Mar 4, 2008 01:38 PM
vteckyle
19
Dec 25, 2006 05:39 PM
T"u"Rtle
May 17, 2006 12:06 AM
x_outlaw_x
Jan 4, 2006 09:51 AM
Turbo_y8
May 13, 2005 10:09 AM
