Which altenator do i get for JDM b16?
Old Mar 3, 2010 | 06:33 PM
OOOtony's Avatar
Default Which altenator do i get for JDM b16?
What alternator do i get for the 99 JDM b16A2?
my alternator went out and i just purchased from autozone that was for the 99 honda civic si.
i think they are slightly different im having a hard time putting in the bolts.
Old Mar 3, 2010 | 06:42 PM
iamthefollower's Avatar
Default Re: Which altenator do i get for JDM b16?
that is the correct alternator to fit on that motor.
Old Mar 3, 2010 | 07:22 PM
mrharmonic's Avatar
it all bolts up the same you shoulds have any prblems at all
OOOtony's Avatar
when i went to get it there was 2 kinds. one was for made in Canada and the other wasn't is there a difference?
Old Mar 3, 2010 | 07:45 PM
forcefedferio's Avatar
actually, they are different. i believe the bracket is what is different. you need to use your stock alternator bracket for a 99-00 civic Si if you want to use the stock Si alternator.
Old Mar 3, 2010 | 08:09 PM
honda305's Avatar
i have a 96 civic with a b16a2 and when i had to change my alternator i got a alternator for a 00si and it didnt work. i ended getting a gsr alternator and it worked fine
Old Mar 3, 2010 | 08:43 PM
OOOtony's Avatar
so i did get the wrong one. did you get the gsr alternator from an auto store?
Old Mar 3, 2010 | 09:09 PM
FlewByU352's Avatar
For some reason IDK why but I have a JDM B18C-R and things bought in the US didnt fit. I went to the store and got the correct belt for a USDM ITR B18C5. It wasnt even close to fitting. I ended up getting a belt of w/e I dont remember what size to fit it and it barely fit. What a PITA, belts were either too big or too small. Then when I thought the alternator was going I decided to go look up how much one would be at the store. They said for the ITR I would have to contact someone in Japan to ship one over... the ****? Damn JDM awesomeness becoming a PITA lol
Old Mar 3, 2010 | 09:22 PM
OOOtony's Avatar
should ask for the gsr and 99 si just try dem all see what fits and return the one that doesnt its what i did
Old Mar 3, 2010 | 09:37 PM
FlewByU352's Avatar
I tried like every B series belt lol I think what it is IDK if this is all or just mine maybe the B18C-R has a smaller/lighter crank pulley? Isnt the CTR crank pulley like smaller and stuff? Maybe thats why the correct belts wer too big. Sometimes you import these motors and find some hidden surprises. The only thing I found was NGKR Iridium Spark plugs. I've seen people pull them apart to find out its not a factory freak it was built or more common an aftermarket clutch. IDK what it was lol
Old Mar 3, 2010 | 11:09 PM
OOOtony's Avatar
yeah i had before a ctr pulley i dont remember i think it was smaller the belt wouldnt fit with the oem alternator pulley so i got one of those AEM ones that were much bigger and it fit with the oem alternator belt. but i think they sell the alternator belts for the ctr pulley you switch on
Old Mar 4, 2010 | 12:23 AM
Kidnkorner's Avatar
I would think a 95 Del Sol VTEC would be the right one. Is this for a 96-00 civic?
Don't think there is such a thing as a JDM B16A2 considering JDM engine don;t have any number after the last letter, B16A2.
Old Mar 4, 2010 | 04:40 AM
You are correct, I forgot about this. I had to do the same when I put an alternator on my JDM B16.
Old Mar 4, 2010 | 07:03 AM
lemonAIDS's Avatar
I have an 00si alt on my b18a...i thought all b series alts were the same, it's just that lower bolt is a bitch to get in there. I do know that it's possible to rig up a d series alt if you trim the adjustable upper bracket a little.
Old Mar 4, 2010 | 08:17 AM
Schister66's Avatar
Man U FTW
Pm'd with a possible solution
Old Mar 4, 2010 | 08:27 PM
OOOtony's Avatar
i just google jdm b16a2 first thing that came up.
http://www.jdmenginesamurai.com/engi...gine_b16a2.htm
there isnt much diff but was told some comes with an lsd tranny.
can any confirm this
Old Mar 4, 2010 | 08:29 PM
OOOtony's Avatar
thanks.
but i just got an alternator for an 1996 acura integra gsr put it on with no problem i notice the diff. between the 99 civic si it wont even bolt on and even the pulley looks different.
Elson23
10
Oct 26, 2009 09:57 AM
civic1821
May 14, 2009 07:46 AM
jdmcivic1
10
Apr 30, 2009 10:40 AM
DOHC4banger
Apr 13, 2008 07:51 PM
