my 1st time ever at the track (time slips)
Old Sep 7, 2002 | 06:32 PM
JICsube's Avatar
Default my 1st time ever at the track (time slips)
well this was my first time, ran about 5 times at carlsbad
mods- 93 cx, b18c1, no back seats/sparetire, intake and exhaust, stock cx fuel pump, stage 3 clutch and 16 inch rotas on kumhos.
reac. 1.807
60ft- 2.363
330ft-6.480
1/8-9.789/ 74.53mph
1/4-15.043/94.31mph
by the way i have a cracked A-pipe if that matters. any helpful tips too help improve my times? ( i know practice alot) thanks
[Modified by axion7606, 3:40 AM 9/8/2002]
Old Sep 7, 2002 | 06:45 PM
ExospeedAMcrx's Avatar
Default Re: my 1st time ever at the track (axion7606)
the mph is pretty good, that would really be a low 14 sec run on that MPH.
The 60ft is way too high, you must have been spinning like crazy.(he had a typo I think, or I read it wrong. I thought it said 3.3 60ft before)
Reaction time: dont worry about it too much if you are just practicing anyways.
it doesnt make a difference on the ET, 1/4 mile time.
NExt time, try launching it at around 4-5K, dump the clutch but dont keep the gas on all the way.
Gas it, but let off alittle and slowly give gas as you feel the car hook up, then floor it.
The 16" rota's isnt helping much either, but you can still play around with it if its all you got.
Good luck.
Wil
[Modified by exospeedAMcrx, 7:50 AM 9/8/2002]
Old Sep 7, 2002 | 07:17 PM
nsxmatt's Avatar
Default Re: my 1st time ever at the track (exospeedAMcrx)
Actually the MPH is a mid to high 14. I'm trapping 96 mph on a 14.4. Alot of gsr's trap around 97-98 and run low 14's. The 60ft does need some work but it's not horrible. Keep working at it
Old Sep 7, 2002 | 08:18 PM
SoulSurfer's Avatar
Default Re: my 1st time ever at the track (nsxmatt)
Okay I know reaction time has nothing to do with ET but what in the world were you doing when the 2nd yellow lit. I could finish reading Moby Dick in that time!
Overall, 60ft is not bad. You should be in the high 14s.
[Modified by LSDelSol, 2:19 PM 9/8/2002]
Old Sep 8, 2002 | 03:20 AM
nsxmatt's Avatar
Default Re: my 1st time ever at the track (LSDelSol)
"Wow what a pretty green light! I know it means something. Hey track official, what does that green light mean? Go? Ok, thanks! Alright here it goes!"
I'm just joking . Alot of people including me work on the launch on test and tune. I have gotten a 4.xx RT just trying to get the rpm's just right and not worry about being pressured into a good RT. If you were at a bracket race then work on that though
Old Sep 8, 2002 | 10:13 PM
JICsube's Avatar
thanks for the help time too practice launching alot! yah since it was my 1st time i wasnt trying too get a good reaction time, was juss hoping too get into the 14 second mark, but didnt
Old Sep 8, 2002 | 10:55 PM
Kamin's Avatar
edit: owned by my own stupidity.
anyway, try to launch at like 4-5000 and feather the clutch out. the 60' is DAMN good tho.
i can barley squeeze 2.3's on my b16. damn torqueless wonder.
[Modified by KAMiN, 11:56 PM 9/8/2002]
Old Sep 11, 2002 | 11:17 AM
azhatch's Avatar
Default Re: my 1st time ever at the track (KAMiN)
someone says launch at 4-5k and dump the clutch then someone says launch at 4-5k and feather the clutch. Which is going to get you a better 60' time?
Old Sep 11, 2002 | 03:38 PM
gsrvx's Avatar
New User
Default Re: my 1st time ever at the track (socalcivic)
Both can work. I've dumped at 4-5K and had to modulate the gas pedal. Got a 2.2 60ft. I've also feathered the clutch and gotten 2.2s.
BTW, these are on shitty goodyear intrepid tires (stock tires for 13'' vx wheels).
-Rod
Old Sep 11, 2002 | 11:43 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: my 1st time ever at the track (iluvjapan)
r/t dosen't matter w/ the 1/4 mile, the timer dosen't start until you leave the line and cross a sensor,right? or am i wrong i could be wrong......
You can sit at the light for an hour if you want. Makes no difference in ET.
The trap is good for mid-high 14's. You should be able to pull a mid 2.2 60' at least.
Old Sep 12, 2002 | 12:04 AM
SoCal ITR's Avatar
Default Re: my 1st time ever at the track (ActiveAero Ninja Edition)
That trap speed is good for mid 14's. Your 60' could be better, but it's not bad for your first time. From what I see you people baby your clutches. My best 60' times come from feathering it from 7k or so. I pulled a 2.1 on 400 treadwear tires.
Old Sep 12, 2002 | 11:31 PM
JMX's Avatar
JMX
yeah u should get better than a 2.2, i can pull a 2.2 in my heave LS u should be around 2.1
get the launch down and u got some quick times for that car, problem is judging the track your on and the tires u use.....trial and error
Old Sep 13, 2002 | 03:27 AM
UnitZero's Avatar
did you roll through the water box?
you don't need to unless you have slicks, it just cause too much wheel spin. you will drop your 60ft time if you dont roll through the water
Old Sep 13, 2002 | 10:38 AM
JICsube's Avatar
Default Re: my 1st time ever at the track (Metal Siren)
thanks fo rthe help! no i did not run thru the water box lol, soon as i get my a pipe fixed im headed back out too practice some more gotta get those low 60fts!
98ITR#0020
Jul 6, 2004 12:40 AM
blazinb16
Jul 20, 2003 01:26 PM
TwistedSI
24
Apr 12, 2003 09:59 PM
dwn-shift
Feb 17, 2003 03:10 PM
chillly
Nov 4, 2002 11:42 AM
