oil leak ???
more than likely from a leaking distributor O-ring or bad valve cover gasket.
Serious question for you...do you ever search for an answer or are you just creating 10 threads a day to increase your post count? All of the **** you ask is basic and can be found on here with a search or two. Your car is 20 years old, do you really think you're the first one to experience any of this?
SEARCH!!!!!!
SEARCH!!!!!!
well i know for a fact it ain't the oil pan but i'm not sure about the axle seal or rear main seal
btw where's the RMS ?
well i jacked up my car and put it on stands and i clean the bottom and when i turned on the car it was leaking ,but when i did the clutch i change the seal
