speedometer problem!!!
Old Mar 3, 2010 | 03:55 PM
miguey310's Avatar
Default speedometer problem!!!
well i notice it didn't work so i uncover this when i looked at the cluster
can anybody if that's the problem if so how can i fix it??
so what else should check
Old Mar 3, 2010 | 05:53 PM
chivid's Avatar
Default Re: speedometer problem!!!
make sure the speedometer is connected properly on the tranny, put the car in jacks and with the cluster side end of the cable look to see if it spins when you engage the car in gear and let it spin at atleast 2,000 rpms. if it does, then plug it in to your cluster and see if it catches the cable spinning.
Old Mar 3, 2010 | 06:05 PM
miguey310's Avatar
does the plug look good ??
Old Mar 3, 2010 | 06:22 PM
chivid's Avatar
cant really tell from the pic but it does look a lil shorter than normal. try the steps that i wrote first. it might be the cable itself is bad.
Old Mar 3, 2010 | 06:25 PM
miguey310's Avatar
And where on the tranny do i look ?
Old Mar 3, 2010 | 06:28 PM
nycpatron's Avatar
on the top backside of the tranny your going to see it your going to see the cluster cable running into it
Old Mar 3, 2010 | 06:37 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-how-change-tranny-fluid-1325930/
Look at that thread,post #12 and beyond..
Old Mar 6, 2010 | 01:14 PM
miguey310's Avatar
well i was think
Old Mar 6, 2010 | 01:15 PM
miguey310's Avatar
if it wasn't connected to the tranny the miles would not work right ?
Old Mar 6, 2010 | 07:36 PM
miguey310's Avatar
miguey310's Avatar
Old Mar 6, 2010 | 08:09 PM
D16SiHatch's Avatar
correct. no cable, no speed, no mileage registered.
Old Mar 6, 2010 | 08:11 PM
miguey310's Avatar
so my cluster is messed up right ?
Old Mar 6, 2010 | 08:16 PM
chivid's Avatar
well first of all the cable wasnt connected so i mess with the cable first.
Old Mar 6, 2010 | 08:26 PM
EJ1_Sleeper's Avatar
plug cable into speed sensor on trans, and cable into cluster. go for drive. if it doesnt work remove the speed sensor to make sure the gear and everything is spinning then replace the speedo cable (i replaced mine when i did my swap with a used one cause it came apart). worse case its your speedometer gauge.
coot_er
Oct 2, 2005 10:33 PM
crxtreme27
Jan 19, 2005 05:48 PM
cutt
Nov 12, 2004 06:57 PM
loid
Jul 26, 2004 08:33 AM
vaporDA6
Mar 10, 2004 10:16 AM
