No heat!
Old Mar 3, 2010 | 02:09 PM
slowassciv33's Avatar
Default No heat!
Hey whats sup? i just picked up a 02 ep3 and love it so far, the only problem im having with the car is no heat from the blower, when u try to turn the heat on the blower doesnt kick on at all. some thing if i try to turn the ac on the compresser doesnt turn on either. Im new to 7th gens so i dno what fuses to check because they are not label under the dash and the car didnt come with a owners manual
Old Mar 3, 2010 | 02:37 PM
kPRO dz's Avatar
Default Re: No heat!
i believe A/C compressor and heater fuses are in your engine bay. pop the cover and the fuse diagram should under it
Old Mar 3, 2010 | 02:39 PM
ill take a look thanks
Old Mar 3, 2010 | 03:15 PM
Targa250R's Avatar
be professional
Test for power at the blower motor plug when the switch is turned on. If you have power, then the motor is probably bad.
The A/C compressor not kicking on can be related to a number of problems. You should check the refrigerant pressures in the system to start with.
Old Mar 4, 2010 | 02:51 PM
i got power at both wires at the blower so im guessin its shot
1320whtrex
17
Dec 2, 2025 03:47 PM
SIef9
Jan 2, 2009 08:57 PM
8_6 luder
Jan 14, 2007 07:44 AM
six sigma racing
May 1, 2005 07:14 PM
