92 civic, b16 no spark
done everything i could, cap rotar, coil, ICM, wires, plugs.
could it be my distributor power wire(large Blk/yellow)
and if so where does it go? where does it lead
or would it be the ICM on the A plug of the ecu
its good, tried another ecu b16 obd1, and nothing
if i run a new wire the the A21 for the ICM and nothing happens
where would i run a new Blk/yellow?
and i dont have a test tool, sorry
this may sound dumb, but you didn't list battery, its not dead is it? or your fuses? Under dash?and hood?
Always remember the Kiss theory when going throught these problems:
Keep
It
Simple
Stupid
Example: I had a small amount of collant that looked to be leaking from head gasket, I towed to my friends shops to take look at thinking it was blown head gasket, and it was a bad hose leaking from the rear of the motor and the leak was running around the side to the front and I just couldn't see it. More than likly its going to be something dumb that you just over looked. since you sould like you almost replaced your complete ingintion system
Keep
It
Simple
Stupid
The starter must crank the engine to check for spark and the fuel pump primes, suggesting that a bad battery is not the problem. There's no specific fuse for the distributor/spark.
look, battery is fine, fuses are fine, Main relay is fine, only ecu code is oxy sensor since its bad. and out of cash, spent it on a new cap and rotar, since last ones were more then beyond used
all i can think of is if it were the ICM i would be getting code 15 if that were not getting power
but i was thinking if the dizzy wasnt getting power at all from the Blk/yellow i wouldnt get a code
so if i had to run a new Blk/yellow where would i run it to?????
just replaced the A21 ICM wire, no the case. so its the main power for Blk/yellow
where does it lead? so i can check its sorce and or replace it.
worked, car started first 2 turns
Blk/yel wires was broken somewhere. so going to replace whole wire with a new one and add it to the harness.
putting the a21 wire back to normal
92, acura, b16, bad, battery, checking, civic, coil, distributor, engine, good, obd1, spark, troubleshoot, troubleshooting
