where can i find all the 2000 si specs?
2000 Civic Si specs:
ENGINE
Type: 4-in-line, aluminum block / head
Bore and Stroke: 3.19 x 3.05 in (81.0 x 77.4 mm)
Displacement: 97 cu in (1595 cc)
Compression Ratio: 10.2:1
Valve Gear: DOHC 16 valve VTEC
Engine Control: Honda PGM-FI
Power (SAE net): 160 bhp @ 7600 rpm
Torque (SAE net): 111 lb-ft @ 7000 rpm
Redline: 8000 rpm
DRIVETRAIN
Transmission: 5-speed manual (only)
Final Drive Ratio: 4.40:1
SUSPENSION
Front: control arms, springs, sway bar
Rear: control arms, springs, sway bar
BRAKES
Front: 10.3 in vented disc
Rear: 9.4 in solid disc
DIMENSIONS
Curb Weight: 2584 lbs
Weight Distribution: 62.2/37.8%
Wheelbase: 103.2 inches
Length: 175.1 inches
Width: 67.1 inches
Height: 54.1 inches
PERFORMANCE
Acceleration: 7.2 seconds (0 - 60 mph)
1/4 Mile: 15.7 seconds @ 88 mph
Top Speed: 127 mph
Braking: 199 ft (70 - 0 mph)
Roadhandling: .85 g
ENGINE
Redline: 8000 rpm
DRIVETRAIN
SUSPENSION
BRAKES
DIMENSIONS
Width: 67.1 inches
Height: 54.1 inches
PERFORMANCE
Top Speed: 127 mph
Roadhandling: .85 g
Jaysun
Suspension & Brakes
May 31, 2006 08:50 AM
AFAccord
Jul 21, 2005 12:57 PM
