NC FS/FT: 2 Cars...2000 JDM RHD ITR & 91 SI B16a etccccccc
Contact: PM or text 919-218-0546
Price:8000 for integra & 3700 for Civic, Together for 11,500
Mileage: Integra= cluster and chassis is unknown cause of RHD conversion but bottom end has less thank 60k, head has less than 1k
Title: Integra LS Salvage
LOOKING TO TRADE FOR An S2k OR IS300 OR WRX or something along those lines
ETC: Integra will be coming with alot of extra random parts
The bad: No heat,AC,PS,Radio or Speakers
Mods:
Exterior/Cosmetic/Chassis
-JDM 1piece Headlight Front End Conversion
-OEM Front Bumper
-OEM Optional Side Skirts
-Carbon Fiber Hood
-CompositesFab Carbon Fiber Roof Cap
-Carbon Fiber Spoon Style Side Mirrors
-Right Hand Drive Firewall conversion
-PasswordJDM Cooling Plate
-Skunk 2 VTEC Solenoid Cover
-Skunk2 Battery Tie Down
-OEM Type R Spoiler(not Pictured)
- Full 2.5" exhaust with REAL Apexi N1 axle back
Suspension
-4 Lug conversion
-ARP Extended Wheels studs all around
-PasswordJDM Rear 4-point Strut Bar
-PasswordJDM Rear 2-point Lateral Bar
-D2 Full Coilovers
- 16x8 +15 Offset Brand New SportMax 501's w/Dunlop 205/45/16 Tires
Interior
-MemoryFab S68 Carbon Fiber seats
-Sparco Color 2 steering wheel
-All OE Honda Faux Carbon Fiber factory pieces
-JDM ITR Carbon Fiber Gauge Cluster
-Autometer Carbon Fiber Oil Pressure Gauge
-AEM Uego Wideband Controller
-JDM Integra Type R Armrest Delete
-JDM Integra Type Rx Shift Boot and Carbon Radio Block off
-Sparco Carbon Fiber Pedals
-CompositesFab Carbon Fiber Door Panel inserts
-CompositesFab Carbon Fiber Fuel pump covers
Engine Management
-Chipped P28 with crome
Fuel
-B&M Fuel Pressure Gauge
-Walboro 255lph Fuel Pump
Motor:
B18c5
OEM P73 Pistons
Hondata Intake manifold gasket
ARP 9mm Rod bolts
ARP B18c5 Head Studs
Head:
2000 JDM Type R
Rev Racing dual valve springs
Supertech Retainers
OEM 3 layer headgasket
skunk2 cam seal
buddy club cam gears
RLZ RACE Valve Job and P&P
OEM HONDA Type R Valves
GREDDY Timing Belt
Skunk2 Pro Series Intake manifold Portmatched to a
Professional Products 68mm TB
RC 310cc Injectors
3" Injen Short Ram Intake
Custom Made header(only one made like this)
Hytech Test Pipe
Tranny: LS tranny
fidanza 7.5lbs flywheel
ARP pressure plate bolts
ARP flywheel bolts
Exedy stage 1 Clutch kit
how she looks right now, i can get everything painted for alittle bit extra price
I can get more pic if wanted
1991 Honda Civic SI
Mileage: 183k on cluster, 47k on motor
Title: Clear
The good: SHAVED AND TUCKED ENGINE BAY WITH FRESH RIO RED PAINT!!
The bad:Flat Black, No interior, heat not 100% hooked up
Mods:
Exterior:
-JDM Yellow Foglights
-Window Visors(not pictured)
-Rolled & Cut fenders
-Rear wiper Delete
-Amber Corners
Suspension:
-Eibach Sportline Springs in Front with sleeve over
-H&R Race Springs In Rear With sleeve over
-KYB AGX Struts
-Front And Rear Strut Bars
-Roll Cage(welded in)
-OEM Swaybars
-Brembo Drilled and Slotted Rotors
-Hawk Pads
Interior:
Not much there lol
-Grant 330mm Steering wheel
-Type R replica Shift ****
-4 Point Racing Harness
Engine management:
-Stock PWO or chipped p28
Motor: JDM B16a
-JDM ITR HEADER
-JDM ITR Intake Manifold
-JDM ITR Valvetrain
-JDM ITR CAMS
-JDM ITR Throttle Body
-Hondata Intake Manifold Gasket
-Hasport Shift Linkage
-Innovative steel mounts
-Ebay Short shifter
-Full 2.5" exhaust
-All New Tune up
-New OEM headgasket
-NEW OEM timing belt
-New OEM water pump
Transmission: XSi Transmission
-CC Stage 3 Clutch
-7.5lbs Flywheel
-DSS Stage 2 Axles
im sure there is more i forgot
here is pics
Mods:
-OEM Front Bumper
-Carbon Fiber Hood
Suspension
-4 Lug conversion
-D2 Full Coilovers
Interior
Engine Management
Fuel
Motor:
B18c5
OEM P73 Pistons
ARP 9mm Rod bolts
Head:
2000 JDM Type R
Supertech Retainers
skunk2 cam seal
GREDDY Timing Belt
RC 310cc Injectors
Hytech Test Pipe
Tranny: LS tranny
ARP flywheel bolts
1991 Honda Civic SI
Title: Clear
Mods:
Exterior:
-Rear wiper Delete
-Amber Corners
Suspension:
-KYB AGX Struts
-OEM Swaybars
-Hawk Pads
Interior:
Not much there lol
Engine management:
Motor: JDM B16a
-JDM ITR HEADER
-JDM ITR Valvetrain
-JDM ITR CAMS
-Ebay Short shifter
-Full 2.5" exhaust
-All New Tune up
-New OEM headgasket
-New OEM water pump
-CC Stage 3 Clutch
-7.5lbs Flywheel
-DSS Stage 2 Axles
here is pics
oh man the hatch moves out
burn 1st and 2nd and some of 3rd and will chrip 4th gear easily
very fun car
very fun car
watisjdm
May 14, 2010 07:25 AM
RPRacing
May 22, 2009 11:50 AM
ECKOTYPER
Aug 13, 2007 01:53 PM
iwannaboostmyteg
May 23, 2004 11:44 PM
