suspenion resoration.
i want to restore my suspension ride quality back to factory. i want to replace all bushings and balljoints and bolts.
up front, the lower arm bushings look cracked so they are on the hit list to change them. i want to change the just the bushings rather than replacing both arms, because they are expensive. buying the bushings i save a couple hundred dollars. if anyone has done this before shed some light on how to swap in new ones.
in the rear the only thing i can think of to replace is the upper arm with the balljoint. i called honda, they said that the leading and trailing arms really don't sale to often and really only get replaced when they are bent?
so if anyone changed parts in these area's please share your input. thanx
Sanj
Oct 17, 2005 06:45 PM
Jays91DXhatch
Apr 27, 2005 08:19 PM
