popping out of gear??
Old Sep 7, 2002 | 04:10 PM
b20civic's Avatar
Default popping out of gear??
Well, I already know that my 3rd gear synchros are bad, because it grinds when i shift above 6 grand, sometimes causing me to miss shift. So i purchased the 3-4 synchros sleeve set. Just havent gotten around to tearing it apart.
Today, during a race, i miss shifted, and scratched 3rd gear. Now my shifter is coming out of 3rd gear by itself. It wont stay in gear, unless i hold it there. And it takes nothing more than a finger to pull it out of gear, when im driving in that gear. None of the other gears have this problem, nor do i ever miss shift, or grind the other gears. Im curious as to what would cause this problem of popping out of gear. Any ideas? Shift selector fork bent maybe? Or did i finish off the 3rd synchros?
I would rather have as little down time as possible, otherwise id just tear into it and inspect everything. Any help would be appreciated. thanks
ERIK
Old Sep 7, 2002 | 10:54 PM
3rdGteg's Avatar
Default Re: popping out of gear?? (b20civic)
Sounds like one of my problems; here check this post out https://honda-tech.com/zerothread?id=244669
BTW, how much did u get the 3-4 synchro for? Also for which tranny?
Old Sep 8, 2002 | 02:09 PM
jcivicsib20's Avatar
My buddys tranny popped out of gear before and it was because of the housing not having enough oil. Fill it up and try it out.
Old Sep 8, 2002 | 11:33 PM
BoOsTeD_eK's Avatar
Default Re: popping out of gear?? (jcivicsib20)
yeah if there isnt enuff oil...the tranny starts spitting ou tthe gear...you can actually feel the shifter "slide" out.
Aquafina
Transmission & Drivetrain
Sep 6, 2008 11:14 PM
tomato_man
Apr 15, 2007 06:27 PM
Evil_Ek
Feb 9, 2006 08:33 AM
wrx'n you
Dec 21, 2005 08:20 AM
b20civic
Dec 2, 2002 05:28 PM
