what does it mean when!!!!
Old Mar 2, 2010 | 11:30 AM
superhatchbackbros's Avatar
Default what does it mean when!!!!
what does it mean when u put the key in and turn it to the on position where the check eng light and oil light and fuel pimp prime and it doesnt come on. and turn the key forward all the way to start the car and then the lights come on and the car tries to start and then dies .5 secs.. DOES ANYONE KNOW WHAT could cause this problem! please help me thanks in advanced honda-tech members!
Old Mar 2, 2010 | 11:38 AM
redbull-1's Avatar
Default Re: what does it mean when!!!!
From what you described, I would check the battery first.
Old Mar 2, 2010 | 11:54 AM
GlassJAw's Avatar
I would also check your main Fuel Relay, if the fuel pump doesn't prime it will do as you said and stop running once the vapours have been burnt in the cylinders.
Check all fuses under bonnet and dash would be a good place to start looking for faults.
Old Mar 2, 2010 | 12:41 PM
hey everyone it was the IGNITION SWITCH! thanks everyone for ur help!
Old Mar 2, 2010 | 02:55 PM
02 accord's Avatar
I knew that.
Old Mar 2, 2010 | 03:05 PM
questions for everyone! car runs and drives fine now! but throwing code 15 ignition out put signal! now isnt that in the dizzy? but the car cranks over just fine.. does it mean its just defective and i should switch it out? and see if the code goes away? i also reset the ecu and code still is on!
jays35
Jun 17, 2014 02:31 PM
gsmith93
May 13, 2013 02:37 PM
lazylegs15
Sep 14, 2008 10:20 PM
ducky21
Jul 28, 2006 03:10 PM
