will da camber kit fit crx?
Old Mar 2, 2010 | 09:48 AM
crazyboy's Avatar
Default will da camber kit fit crx?
just as the title states, ill be trading my da power folding mirrors for a camber kit if it fits my car. i guess its the type that replaces the control arm in from. any help is appreciated thanx
Old Mar 2, 2010 | 03:31 PM
crazyboy's Avatar
Default Re: will da camber kit fit crx?
anybody?
Old Mar 2, 2010 | 04:30 PM
lvmevo's Avatar
well my friend ordered one for his da and i got one for my 90 civic looks identical i should work fine. might have clearance issue on the passenger side. because the arm is longer it might hit the pinch weld inside the fender well . (on the frame) i bent mine and grinded it. good luck
Old Mar 2, 2010 | 04:52 PM
ED9man's Avatar
forget the camber kit go get an alignment and make sure nothing is worn out in your suspension, that's the reason your tires are wearing, not camber
Old Mar 2, 2010 | 05:12 PM
KevinT707's Avatar
Almost positive it will work.
Only toe can be adjusted on an alignment, and although toe will wear tires out the most it's also important that one does not have TOO much camber. On a DD vehicle it would be most efficient to have maximum contact patch from tire to ground.
Old Mar 2, 2010 | 08:30 PM
crazyboy's Avatar
ya nowhere in my post did i say my tires were wearing. i know toe is the main cause, my question was does a da camber kit fit a crx? simple as that
Old Mar 2, 2010 | 09:17 PM
.Manny.'s Avatar
Touching My Member
unless you need to add negative camber while at the race track, leave the camber kit off of the car. simple as that. Trade your parts for other useful parts
Old Mar 2, 2010 | 11:14 PM
Honda_ThuGZ's Avatar
Yes it will fit
Old Mar 3, 2010 | 08:37 AM
crazyboy's Avatar
Originally Posted by Honda_ThuGZ
Yes it will fit
thanx for answering my question. ill be trading today
Old Mar 3, 2010 | 08:38 AM
crazyboy's Avatar
or i culd actually put the camber kit on now that my question was answered....
journeyquest
Apr 3, 2016 02:54 PM
wilaivue
Jun 27, 2010 06:52 PM
91EF919
Jun 30, 2009 04:11 PM
integraboi1010
Oct 21, 2006 03:51 PM
crx1009
Apr 5, 2006 09:57 AM
