How big of injectors should i RUN? Help thanks
Old Mar 2, 2010 | 08:41 AM
hrs-parker's Avatar
Default How big of injectors should i RUN? Help thanks
Head
2000 GSR RLZ head
Skunk2 Pro2s
SKunk2 Cam gears
SKunk2 Flat Valves
Skunk2 Dual Valves and Ti Retainers
Ferrea Valve seals, locks, seats, and bronze valve guides
TWM 52mm ITBs
RMF replica headers
ITR lmas
THE BLOCK
Bensen Sleeved 84mm Gsr block
12.5:1 Manley Pistons
Crower Rods
Arp Head studs
Arp Main Studs
Darton Main caps
Moroso Oil Pan
Cometic 84mm .030 head gasket
ACL race bearings(rods,main,thrust)
ITR oil pump
ITR water pump
Oem Main seal
give or take thats the start. I was wondering if 470s are good enough or not? or should i go bigger. trying to sell my 310s and getting bigger ones. PLease lmk what you guys think.
appreciate it!
Old Mar 2, 2010 | 09:16 AM
OH_1fstgsr's Avatar
Default Re: How big of injectors should i RUN? Help thanks
ID725's, these might seem big but do some research on them. They have a very good spray pattern over the RC's.
Old Mar 2, 2010 | 09:19 AM
GagnarTheUnruly's Avatar
I might be interested in buying your 310s if you decide to switch them out. LMK.
Old Mar 2, 2010 | 10:07 AM
neverstop's Avatar
RDX injectors look cheap and have a great spray pettern plus oem reliable
Old Mar 2, 2010 | 10:09 AM
hrs-parker's Avatar
ill research them and see what i can do. thanks
Old Mar 2, 2010 | 10:10 AM
hrs-parker's Avatar
pmd you
ill look in to them
i was think no more than 550's but ill research some more..thanks guys
Old Mar 2, 2010 | 05:12 PM
OH_1fstgsr's Avatar
Take a look at this thread.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/bosch-900cc-injectors-vs-rc-550cc-2687802/
I am starting to plan a similar build as yours. So I'd like see how yours goes.
Early planning
85x87 GSR block
12.5-13:1 compression
GSR head that flows at or very near 300cfm
Victor X CnC'd or a Magnus IM
ID725 injectors
the car will have a street tune on 93 and a race tune on 100
Still in the planning stages
Good luck on your build keep us updated.
mayfly
Jan 17, 2012 12:54 PM
hrs-parker
Transmission & Drivetrain
Apr 20, 2010 11:16 AM
k2kyl
Nov 20, 2008 04:56 PM
JayDeeEmm
13
Jun 27, 2008 01:01 PM
Honda_Fanatic
23
Nov 9, 2007 07:54 AM
