Finished painting my garage; lower drywall edge?
Old Mar 2, 2010 | 07:03 AM
Kyle R's Avatar
Default Finished painting my garage; lower drywall edge?
I just recently finished painting my garage (bright white; it looks like a hospital now lol). Anyways, I want to add some kind of trim to the bottom edge of the drywall (where it meets the concrete). Any ideas? Thanks.
Old Mar 2, 2010 | 07:10 AM
Scott_Tucker's Avatar
Default Re: Finished painting my garage; lower drywall edge?
I always recommend a darker color paint along the bottom edge of the wall because that is where most of the dirt accumulates.
Old Mar 2, 2010 | 08:40 AM
Kyle R's Avatar
Yeah I am back and forth about painting the bottom edge (up maybe 3 feet or so) all the way around. I was considering some kind of stainless steel "trim/paneling." Thoughts?
Old Mar 2, 2010 | 08:57 AM
gabebauman's Avatar
Vinyl Base Moulding, (it comes in a big roll at Home Depot, Menards, Lowes, etc).
http://www.easy2diy.com/cm/easy/diy_...ge_id=35743505
Old Mar 2, 2010 | 09:19 AM
Kyle R's Avatar
^Sweet. Thanks for the idea.
Old Mar 2, 2010 | 09:36 AM
gabebauman's Avatar
No problem. I used it in my basement when I remodeled. It's more resistant to water and other elements than wood is.
Old Mar 2, 2010 | 11:00 AM
GhostAccord's Avatar
Don't forget to use a bead of silicon or a bonding type sealant between the floor and the molding. That way if you ever spill something or use a really wet mop. The moisture won't be able to get up between the molding and the drywall.
Old Mar 2, 2010 | 11:03 AM
Kyle R's Avatar
Anyone using aluminum/stainless steel sheet metal on their garage walls?
Kyle R's Avatar
Thanks for the tip
Old Mar 2, 2010 | 11:09 AM
Friend of mine has 6" of thin brushed aluminum diamond plate along the floor and more on his cupboard doors. Looks pretty sick and you can seal it up the same way as the vinyl molding because his was scored and bent with a 1/2" bottom lip. $$$ I'll see if I can get him to take a pic.
Old Mar 2, 2010 | 11:42 AM
Kyle R's Avatar
^Cool thanks. Yeah the vinyl would definitely be the less expensive option.
Old Mar 3, 2010 | 12:39 PM
Kyle R's Avatar
I'm considering painting the lower half of the wall another color besides white. Any suggestions? I was thinking of using dark gray?
Old Mar 3, 2010 | 12:55 PM
I think gray or dark blue looks good. Aluminum plate is nice too but expensive. Although its easy to clean.
Old Mar 4, 2010 | 08:09 AM
honda-junky's Avatar
I heard that flat white paint reflects better than gloss white... has anybody else heard this?
Old Mar 4, 2010 | 01:12 PM
Kyle R's Avatar
I've never heard that before.
Old Mar 4, 2010 | 02:29 PM
xzodiackillerx's Avatar
gloss is easy to clean. flat white will look like crap in a few weeks.. use the cove base and seal it like stated before
Old Mar 4, 2010 | 03:00 PM
srmofo's Avatar
im sure someone on this site has:
www.garagejournal.com/forum/
lots of other good ideas there also, I visit it more than any other forum now
Old Mar 5, 2010 | 02:17 PM
Kyle R's Avatar
^Thanks for the link
dd_jdm
Paint and Body
Sep 14, 2007 08:11 AM
ILuvMyJdmDc4
Apr 24, 2007 10:33 PM
sixfiveoh
Feb 21, 2007 12:27 AM
SL!M
Mar 23, 2003 06:41 AM
phear
25
May 7, 2002 09:40 PM
