Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
98 crv weird noise started
Old Mar 2, 2010 | 04:27 AM
luciffer's Avatar
Default 98 crv weird noise started
98 crv, 5spd, awd, everything was in good working order, no noises or anything until the other day.
It started making a whirring noise, sounds like its coming from something that spins (with the fan shutoff so its not that). When sitting in the driver's seat its definitely coming from the front of the car and to the right of the driver's seat.
The noise doesn't happen at idle, its remains the same when accelerating or driving at a constant speed. Turning left or right or driving straight doesn't make a difference. The noise goes away when slowing to stop after the brakes are fully applied even if the car is still rolling to a stop. The noise is still there while the car is moving regardless of whether the clutch pedal is in or out.
Any ideas where i should start looking? could it be a wheel bearing or more likely the shaft that goes back to the rear wheels?
Old Mar 2, 2010 | 04:44 AM
eghatch4sale's Avatar
Default Re: 98 crv weird noise started
If u are hearing it when your drivivng and considering you have a 5spd could be your isb (input shaft bearing)
Old Mar 2, 2010 | 06:05 AM
luciffer's Avatar
if it was the ISB would it not still make the noise while the car is running and in neutral?
i'll double check but i was pretty sure i checked at idle with the clutch pedal depressed and foot off the clutch pedal and no noise while the car wasn't in motion.
pr1madona
Honda CR-V & Element
Dec 3, 2016 11:27 AM
DannyGo
Oct 18, 2014 09:42 PM
Arman Sesar
Transmission & Drivetrain
Jun 28, 2013 03:18 PM
maximusmda
Oct 7, 2009 03:22 AM
NinoBrown
Sep 26, 2006 08:54 AM
