Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Please HELP !!! 99 crv propeller shaft
Old Mar 2, 2010 | 03:44 AM
eghatch4sale's Avatar
Default Please HELP !!! 99 crv propeller shaft
I have a 99 5spd crv and I'm going to be in need of replacing my propeller shaft and I called a local junkyard and found one for an automatic 98 crv and they said that there is a differance for the shafts is this true I want to make sure I replace it b4 it goes bad !!!!!! So my question is are all 97-01 propeller shafts the same regardless of the year or if it is an automatic or manual ? I know I could buy the rockford u joints and fix it that way but seems more headache then it is worth thanx in advance
Old Mar 2, 2010 | 06:33 AM
qwrty's Avatar
Default Re: Please HELP !!! 99 crv propeller shaft
i dont think that theres a difference.. coz i replaced one of my V's prop/drive shaft
that came from a manual lower model, it fits right through!
http://www.hondapartsunlimited.com/i...&submit=submit
i tried using a qoute from both 99-5spd and 98-at...
same part no. hen your good to go!! try to low ball them for
the price and tell them that youll take your chance,,LOL!
they might give it to you cheaper! but inspect first what they are
selling, it might be a bad shaft too.. youre just wasting money, tell
them also or if your gonna pick it up, put a good support on the cross
joint, coz most of the issues starts from there..
HTH..
good luck!
Old Mar 4, 2010 | 12:43 PM
B17AGSR's Avatar
Just rebuild it, its a lot cheaper. The universal joints are made by a company called http://www.rockforddriveline.com/. My machine shop installed it for about $100. Both joints were about $70. It fixed the play the propeller shaft had.
Old Mar 4, 2010 | 04:46 PM
I called many places and no one will install the rockford parts !!! There is a place that rebuilds them for 450 local I just am debating if I want to do it now or just pull it off and run it as fwd since I think the snow might be done
pearlcfcivic97
Jun 17, 2007 12:35 PM
92civichatch1
Feb 26, 2006 01:23 PM
dutchman5
Jan 14, 2003 11:12 AM
