no working signals!
(DB8)ok iv tried to research this for awhile now, and i cant seem to find my problem. SO my signals do not work at all but my hazards so work. i checked all the fuses twice! even the one on the right (the 10 on the white thing) also used a working hazard switch, relay, new fuse on the whiite with 10, and another lever. seems not to work, so im stuck with no answers and no one to ask. can some one please help me out i am not tryin to get pulled over nor use my hands in the rain. thanks (noob)
I had the same exact issue. It ended up being the turn signal switch itself. I ended up replacing the switch for the wipers and turn signals and it solved my problem. I was really confused also because my hazards were working fine. I've read that a bad hazard switch could be the issue also, (even if it is operating normally).
i got the same problem, happened after i e-braked into a snow bank, pulled out my corner light backing out, and busted a bulb popping my fuse, replaced the fuse and all the bulbs started working again but the signals didnt work, was fiddling with it one day, had the hazzard switch out, and it started working again and just quit a few days ago, ive tried a different signal switch, but didnt help.
im gonna look at mine tomorrow
JcHonda69
Nov 18, 2017 05:01 AM
