Help!! My car isn't running!
Old Feb 28, 2010 | 07:02 PM
Dc2phil's Avatar
Default Help!! My car isn't running!
I have 96 integra ls. When I try to start my car it won't start or click. All my elecrical turns on. I check my starter at autozone they said it was ok. Then I tryd my battery he said it was bad. So I got a new battery and it still don't work. Any ideas????? Thanks
Old Feb 28, 2010 | 09:19 PM
TheAsian's Avatar
Default Re: Help!! My car isn't running!
Check grounds. Check your tranny ground to be specific. It will ground under the soft hose for the clutch.
Old Mar 1, 2010 | 05:33 AM
Dc2phil's Avatar
Ok I'm pretty sure it's that. But what do I replace? Or how to fix it? Thanks
Old Mar 1, 2010 | 06:15 AM
GSR936's Avatar
check your grounds and check your fuse under the engine bay
Old Mar 1, 2010 | 09:50 AM
TheAsian's Avatar
You measure resistance of the ground wire from the tranny to chassy side. To test the wire then from same side tranny to tranny to check connection and chassie to chassie.
To replace the cable you can just get some heavy gauge wire like 8 use a good connector that seals and make your own grounding wires. Its what I do and never fails.
Old Mar 1, 2010 | 04:21 PM
Dc2phil's Avatar
I found what the problem it was the clutch switch
Old Mar 1, 2010 | 07:42 PM
TheAsian's Avatar
Safety switch
Old Mar 2, 2010 | 07:04 AM
Dc2phil's Avatar
Oh ok thanks
Old Mar 3, 2010 | 09:59 AM
2fast4urass's Avatar
hey not to be be negative but if your considering getting rid of the shell just pm me
92eg6_pino
Oct 9, 2010 04:56 PM
95greenteg
Nov 7, 2005 01:32 PM
MiMiK
Jul 11, 2005 11:14 AM
96jdminteg
Sep 13, 2004 05:19 AM
ferio 95
Aug 22, 2004 12:53 PM
