what part is this?
Can someone tell me what this part is this or part number at honda so ican get it, im trying to put everything back together on my car since the accident thanks.
Looks like cruise control.
"Retail" prices from HondaPartsDeals.com. It's listed under CHASSIS > AUTO CRUISE.
WIRE, ACTUATOR
17880-S2A-A01
$26.67
SEAL, THROTTLE CABLE
17921-SA4-730
$4.82
ACTUATOR ASSY.
36510-PCX-A01
$357.68
BRACKET, ACTUATOR
36614-PCX-A01
$19.63
COVER, ACTUATOR
36621-PCX-A01
$20.52
BOLT-WASHER (6X12)
93404-06012-07
$0.75
BOLT, FLANGE (6X12)
95701-06012-08
$0.83
Good luck on rebuilding your car.
www.car-part.com might also help out.
WIRE, ACTUATOR
17880-S2A-A01
$26.67
17921-SA4-730
$4.82
ACTUATOR ASSY.
36510-PCX-A01
$357.68
BRACKET, ACTUATOR
36614-PCX-A01
$19.63
COVER, ACTUATOR
36621-PCX-A01
$20.52
BOLT-WASHER (6X12)
93404-06012-07
$0.75
BOLT, FLANGE (6X12)
95701-06012-08
$0.83
If you don't use cruise control, you may consider not buying a replacement. That's a perfect spot for a catch can which might be a bigger benefit. I took mine out just to save weight (along with gutting the trunk etc).
cincyb20ek
Apr 18, 2011 02:51 PM
SiMateoAko
Sep 10, 2005 07:09 PM
