CEL code 16 help
Old Feb 28, 2010 | 05:12 PM
98gsr-808-91dx's Avatar
Default CEL code 16 help
my hatch throwing code 16. looked it up and its the fuel injectors. i got a d16y7 and converted to obd1. using the injectors from a 94 civic dx and the intake mani.threw that code so i put the injectors from my ls motor which is obd0. so changed over the harness along with the resistor box and still same code?? any ideas?? when the obd0 ls injectors are in my DA the car runs fine. do they not work with the dx mani? any ideas?? thanks
Old Mar 2, 2010 | 09:25 PM
efsleep5's Avatar
Default Re: CEL code 16 help
may sound silly but did u convert from dpfi to mpfi, that would def. throw a code 16 cause it's not compensating the other two injectors. if u did make sure the two yellow/black wires form the stock dx injector plugs wire to the single yellow/black wire from the injector box. the yellow wire to the brown wire from number 1 injector and the red wire to the light blue wire of the nmber 3 injector. the red wire from #2 injector goes to A3 n the yellow wire from #4 injector goes to A7 on the ecu plug. i would personally start w/ obd0 w/ the resistor box n once u get things running smoothly switch to obd1 injectors w/ no resistor box and an obd1 dizzy. if u need any more help w/ the wiring let me know n i can walk u through this
Old Mar 3, 2010 | 08:36 AM
ok thanks for the trouble shoot diagram. efsleep5 i go im u see if any steps i wen miss.
mahalos!!....
Old Mar 3, 2010 | 12:40 PM
JDM_DB2's Avatar
are you using the right ECU?
Old Mar 3, 2010 | 12:51 PM
ya using the p06 ecu out of a 92 eg dx
thebigchili
Jul 7, 2010 04:56 AM
msinsky14
Mar 31, 2009 04:18 PM
dem0nk1d
Aug 16, 2007 02:58 PM
Magic Wheels
Jul 17, 2004 02:03 PM
zccrx
Apr 2, 2003 07:03 AM
