pr4 vtec......(obdo)
Old Feb 28, 2010 | 03:03 PM
efhatch_311's Avatar
Default pr4 vtec......(obdo)
ok guys.i'm back on this subject again.Has anyone heard,ran, or know anything about running a pr4 ecu with vtec?? i asked around and all i get is that it isnt possible.i've done research and know it is possible but i dnt knw for sure if u can run it with the wires being hooked up like a normal pr3 instead of an rpm activated switch. When a ecu is chipped i knw its for timing and fuel maps but can the chip activate a pin on the ecu plug to do something it didnt do b4? I.E- the a8 pin? any information u guys or even gals .lol. have would be greatly appreciated! later..
Old Feb 28, 2010 | 03:27 PM
crx_si-r's Avatar
Default Re: pr4 vtec......(obdo)
you would need to get it chipped. and have it done the way the PS9 is used to run a vtec motor. but why not just buy a PR3 and do it right
Old Feb 28, 2010 | 04:27 PM
Clipsed's Avatar
I have the PR4 obd0 ECU that you'd need to do this, hit me up via PM, I'll sell it to ya for cheap!
Old Feb 28, 2010 | 04:53 PM
dohc_star's Avatar
if u plan on chipping it wouldn't in make sense to just obd1 it the jumper is easy and you now have unlimited possibility's
Old Feb 28, 2010 | 05:06 PM
crx_si-r's Avatar
you kinda made my head hurt.
if you chip an obd0 PR4 why would you use a jumper? are you going to jump to another obd0 ecu? if you chip a pr4, then you just need to add the vtec solenoid wire to the a/c or p/s switch. but doing this will elimate either one if you have it already running in your car.
i have an easy solution for you. buy my PW0 its ready to go, no need for chipping.
Old Feb 28, 2010 | 07:55 PM
Well the reason i ask is because when i was building the motor,i traded my dx axles,shift linkage etc for pistons,timing belt,and a bunch of stuff for the motor and the guy threw in a ecu thats says b16 vtec on the cover.He said it worked so i took it ofcourse.well few months ago i finally noticed it says pr4 on it.so i popped the cover off and it is a chipped pr4.So now 4 loong years later i have my motor complete and almost ready to fire.i miss my car so damn much and its killin me having a fresh motor in it.so it leads me to ask the question about that ecu.i have it.so y not just get it goin with it u knw?
Old Feb 28, 2010 | 08:17 PM
i dont have a/c or p/s in my car.the only way i know how to make vtec work is the rpm activated switch if i cant hook it up like a normal vtec ecu.
Old Mar 1, 2010 | 01:04 AM
My_EFsedan's Avatar
i have an obd0 lsvtec with an obd0 LS ecu chipped no rev with an external vtec controller (my monster tach, bitch all you want). works for the last 6 years with no problem. no knock/oil pressure/2nd o2 blah blah blah.
my cousin has an obd0 ls ecu that has vtec chipped into it..with all the other knock/pressure sensor ****.
have you even tried that ecu yet?
Charlie Moua
10
Mar 14, 2010 08:50 AM
dylokjai
Apr 19, 2007 02:43 AM
freakin
Jan 16, 2006 09:28 PM
drvfast
Apr 4, 2004 09:18 PM
untitled
Apr 25, 2003 09:53 AM
