clutch feels loose after flywheel resurfaced
Old Feb 27, 2010 | 09:20 PM
hatchet_honda's Avatar
Default clutch feels loose after flywheel resurfaced
im swapping my d15b into another si hatch i just bought. i bought a new clutch disc and pressure plate. i already have a lightweight flywheel so i just had it resurfaced. well the motors in now and when i hooked up the clutch cable i had to adjust it all the way to get the cable tight...is this normal for a resurfaced flywheel? im assuming the release bearing has to move forward more now that the flywheel is thinner but its only by thousandths of an inch. i didnt expect it to have this much play
Old Feb 27, 2010 | 10:34 PM
D16SiHatch's Avatar
Default Re: clutch feels loose after flywheel resurfaced
when you depress the pedal does it feel out of the ordinary or does it seem normal? are you sure it has more play now than it did before?
Old Feb 28, 2010 | 09:42 AM
well the clutch pedal feels like it should now...but i had to adjust the cable all the way. i cannot turn the adjuster nut any further.
Old Mar 2, 2010 | 12:21 AM
bump
Old Mar 2, 2010 | 12:24 AM
and the damn clutch pedal squeaks on this hatch too gayy...anyone? my cable is adjusted almost all the way. it feels spongy to me
Old Mar 2, 2010 | 12:20 PM
D16SiHatch's Avatar
shouldn't feel spongy, its a cable actuated clutch. couldn't tell you why you had to adjust that nut so much further though. all i can figure is this new clutch assembly is less thick than the old one and therefore you have to adjust more slack out for the t/o bearing to begin to come in contact with the pressure plate.
88hfef8
Mar 26, 2008 08:02 PM
ridin98civic
Nov 15, 2006 09:55 PM
Origin
Sep 11, 2005 08:00 PM
EG_93Civic
12
Jul 2, 2003 03:31 PM
89 CRX SI
Sep 25, 2002 07:04 AM
