Wiring Job
I just got an 88 civic hb with the d16a6. The guy that had it tried to do a tuck job and slaughtered it. Can anyone help with undoing the mess and getting it back to factory? This is getting on my nerves. If they didn't know how to do a tuck job then they should have left it alone.
I would like that and also where they come out of the fire wall. They made holes in the fender area to run them out of so I have no idea which wires came out of which holes in the engine bay.
find the wires that go to the head light connectors. then follow that whole section back until you get to the egg shaped seal that plugs the hole in the fire wall. where that plug is, all the wires from that point to the head light connector are the wires that go through the firewall. it'll be the same for both the driver's side and the passenger's side.
on the chassis harness/under dash harness, there is one ground that bolts to a 10mm bolt right behind the hood latch release. there is also one that bolts under the dash somewhere next to the steering column, but it's hard to tell over the interwebz exactly where.
importboi22
May 31, 2004 02:31 PM
