something wrong with my antenna please help
ok when i turn my key on i hear the antenna motor work and when i turn it off i hear it again .. but my antenna is stuck up .. if i have my brother push down on it when i turn the key it will take the antenna down if he lets it go .. and when i turn it back on it will send the antenna out but wont go back down unless its pushed on .. so i was wondering what might cause that? is the antenna not connected or maybe broke? i cant pull it out so i dont see how it work be broke or disconnected though .. so if you might have any thought on this please let me know .. thanks
a fairly easy fix IMO....I had the same problem. The plastic reel thats inside the metal mast that pushes and pulls the mast up/down is old and brittle, so it more than likely broke off at the end. I bought a Antenna Mast kit for around $15(ebay) and fixed it myself. After alil research I found a tutorial on the job and had it done in about and hour. The antenna mast cant be pulled out unless you take off the antenna cap nut and black base...
SleepinGSR
Feb 27, 2002 02:03 PM
