Confused about JDM 98R Spec Transmission
Old Feb 27, 2010 | 07:14 PM
JDM_nUt's Avatar
Default Confused about JDM 98R Spec Transmission
Will the JDM 98R tranny 100% bolt on our engines? Just as if I bought a USDM ITR tranny, bolt everything up and drive heR. My concern is will the axles, starter, etc i have work on the JDM tranny. I know it may sound silly, thank you all in advanced.
Old Feb 27, 2010 | 07:20 PM
cheezthis's Avatar
Default Re: Confused about JDM 98R Spec Transmission
In short, yes, it will. It's the outer axle piece that would be a concern as JDM 98-spec had a 36mm outer spindle if I recall. The inner is the same; therefore, it will work fine on any b18c setup as well as other setups.
Old Feb 27, 2010 | 07:47 PM
JDM_nUt's Avatar
Yes, you are correct about the 36mm outter spindle. So if one where to buy the 98-Spec Transmission, then the USDM 32mm/axle outter spindle would not work? I would then would have to buy the JDM 36mm/axle outter spindle correct, for me to be about to drive heR? Thank you all in advanced.
Old Feb 27, 2010 | 08:31 PM
racebum's Avatar
it works, in short jdm transmission usdm axles
Old Feb 28, 2010 | 07:14 AM
Mike M's Avatar
Founding Member
Trans case is the same, difference is the gearing.
Old Feb 28, 2010 | 07:23 AM
get RIGHT's Avatar
Correct.
sky9
Jun 19, 2012 02:54 AM
suje
Oct 25, 2011 01:44 PM
Boosted_01 R
Jun 21, 2009 04:31 PM
asmallsol
Nov 22, 2005 08:53 AM
1.8LHatch
Jul 31, 2004 08:16 PM
