Will Prelude Vtec rotors fit S2000 calipers?
I'm rocking Prelude calipers with re-drilled grooved rotors at the mo and the drivers side caliper piston is starting to stick. I've got a set of S2000 calipers with brackets etc and wondered if these would work with the Prelude rotors and pads?
Its a Civic SiR too.
Thanks
Thanks
not iirc. I believe the prelude rotor is an 11.1" rotor and the s2000 uses an 11.8" rotor. so therefore the caliper will be too big for the prelude rotor.
You dont need to mill anything. Put the s2000 caliper on the prelude bracket. Now if you were trying to use the s2000 rotor AND bracket not only will it need to be milled, but because its bracket (s2000) pushes the caliper further from the hub, it will need 11.8" rotors as well. You wont need this if you simply take the s2k calipers only and mount them to the Prelude brackets you have already
Well tried the S2K caliper on the lude brackets and the bolt holes simply won't line up. Even tried swapping the gliders in the brackets around to see if that helped which it didn't.
Worth a go i guess, thanks anyways.
Hmm thats weird. it could be just the ITR/Accord Wagon brackets that would accept them. I knew the rear Prelude brackets have closer bracket to trailing arm bolt spacing but not the front caliper to bracket. What bracket is that, a 23T or 25T?
Alucard-1524
Feb 1, 2011 10:50 AM
jasonjai
Suspension & Brakes
Apr 13, 2010 08:10 AM
