Anyone using CROWER STAGE 3 CAMS LSV
anyone using Crower stage 3 cams?
i dont know if i should get them ..
my setup
b18 block 86mm
RS sleeves
Arias pistons 14:1
Eagle rods
GSR head- no port n polish
skunk2 springs n retainers
Edelbrock VictorX Intake Manifold
walbro 255 fuel pump
race headers
car will tuned on race gas
my setup
b18 block 86mm
RS sleeves
Arias pistons 14:1
Eagle rods
race headers
you can compare pro 3 to these cams
toda spec d
bc stage 5
rm m25E
toda spec d
bc stage 5
rm m25E
I think he want's to know what you can compare his Crower Stage 3's to. You can try to figure that out if you want OP, the point is they are the wrong cams for a build like yours.
my buddy has a gsr.standard bore.12.5 compression,portnpolish.bbk intake.t.b,race exhaust and good 4-1 header,and other add ons with crower stage 3s. he only made 197 on the dyno cuz these cams are way to big for his setup.he would need a huge bore and possibly stroker kit to get the volume he needs.so idk if i'm any help for you but these cams are def huge.
