ef crank no start
Old Feb 26, 2010 | 06:44 PM
98gsr-808-91dx's Avatar
Default ef crank no start
i swapped in a d16y7 into my 91 ef dx. bought the boomslang obd0 dpfi to obd1 mpfi jumper harness. installed evrything to there instructions but now got a crank no start. any sugjestions??? i replaced the fuel pump. has a 94 dx intake mani and dizzy. sprayed starting fluid into the throttle body and it starts and dies then crank no start.
Old Feb 26, 2010 | 09:25 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: ef crank no start
Can you hear the fuel pump prime when you turn the key to the on position? Does the fuel system have fuel pressure? Which injectors are you using?
Old Feb 26, 2010 | 09:40 PM
ya. i tried changing the main relay before cus the fuel pump was no go. replaced the fuel pump and now getting fuel pressure. pressure gets up to 40psi. the injectors i am using are from a 94 dx.
Old Feb 27, 2010 | 08:11 AM
was throwing cel code 8. tdc sensor. so im thinking its the distributor? the tdc sensor will control the fuel injectors rite? cus must b getting spark to start with starting fluid but dies after?? any 1 got any ideas??
Old Feb 27, 2010 | 08:36 AM
jlicrx's Avatar
what distributor is on it?
Old Feb 27, 2010 | 09:35 AM
Black4thgenEF's Avatar
You're using OBD1 injectors, so what did you do with your stock injector resistor box?
Old Feb 27, 2010 | 09:42 AM
EKkraig's Avatar
If your getting tdc code then your dizzy could have a problem but if its running on start fluid i would check that you getting power to injectors, especially if you hearing the fuel pump kick on. What injectors are you using?
Old Feb 27, 2010 | 09:49 AM
the dizzy is from a 94dx. the injectors are also from the same 94dx.??
Old Feb 27, 2010 | 09:55 AM
romierome's Avatar
are u able to clutch start the car? or u cant do that either?
Old Feb 27, 2010 | 10:02 AM
EKkraig's Avatar
I would test to see if you have power at injectors when key is on (car off). I am assuming you used the dx wiring harness?
Old Feb 27, 2010 | 10:11 AM
yes. using the factory dx dpfi harness with the boomslang ond0 dpfi to obd1 mpfi jumper harness and a po6 ecu.
Old Feb 27, 2010 | 10:13 AM
I guess I managed to make an invisible post, or perhaps your computer is in a state of disrepair that only allows you to see some posts, but not others. What the hell, I'll give you the benefit of the doubt and quote my previous post.
Old Feb 27, 2010 | 10:18 AM
my bad.. but um i not to sure wat i did with the obd0 injector box. but ya i did convert to obd1 with the jumper harness.
obd1 dizzy
obd1 intake mani
obd1 ecu
obd1 injectors/clips with dummy plug
4 wire o2 sensor...
Jamalot
Sep 5, 2015 12:58 PM
str8kustomz
Honda Civic (2001 - 2005)
Apr 13, 2015 01:55 AM
keslerbuilt
Jan 27, 2014 05:45 AM
Chee_dog
Oct 17, 2008 06:39 AM
mattstru
Apr 26, 2006 05:42 AM
