11.0:1 JE Pistons. Streetable with this setup?
half of the stuff in this dosent matter, its just my list.. (aka setup) But with this setup, do you think that installing 11:0 je pistons in replacement of my 9.0:1 will be streetable? Thanks.
Auto Meter 5" Tach With Shift Light
Auto Meter Phantom Oil Pressure Gauge
Auto Meter Phantom Nitrous Pressure
Auto Meter Phantom Air/Fuel Ratio
Auto Meter Phantom Water Temp
(triple gauge pod not shown)
Sony Explode Flip Face 50 x 4 Head Unit
4 4" Infinity Mids
Grant Turing style Steering wheel
Auto Meter Triple Gauge POD
NeuSpeed Short Shifter
Mallory Hi-Fire 2step Stutter Box
MSD Blaster 2 Coil
MSD Blaster Ignition
NGK 7mm Plug Wires
Gude Port & Polished head w/ 3 angle valve job
Gude ThrottleBody
Gude Header
Gude Gorilla Cam
Gude 9,500 RPM ECU
CenterForce Stage 2 Street/Strip Clutch
B & M Fuel Pressure Regulator
JE 9.1 Compression Forged Pistons
Forged Eagle Rods
Full 3" AeroSpeed HeaderBack Exhaust (angled)
NOS Dry Nitrous System
ZEX Purge Solenoid
AeroSpeed Adjustable CoilOvers
MatrixCold Air Intake(not shown)
Erebuni Full BodyKit (i have the front)
Also, would using nitrous with the high compression pistons be dangerous?
Thanks,
Steve Berman
4 4" Infinity Mids
MSD Blaster 2 Coil
NGK 7mm Plug Wires
Gude ThrottleBody
Gude Header
Gude Gorilla Cam
Gude 9,500 RPM ECU
Forged Eagle Rods
ZEX Purge Solenoid
Thanks,
Steve Berman
nitrous loves compression
BUT, it will make it harder to tune. You'll basically have to run race gas whenever you want to spray, or retard the timing a lot
i would go with the 11:1 tho
Hell yea. Thats what I wanted to hear. I love having an all motor beast. And if timimg tuning and Race gas will keep it going under the "gas" then hell yea.. thats the route im going to take. Thanks.
I have also heard that when putting in Eagle rods , you should go with a bearing size larger than OEM specs on the rods. Is this correct?
And are oem bearing the best to use?
Thanks again!!
Steve Berman
Thanks again!!
Steve Berman
u could safely run 12.5:1 on the street w/pump gas. no problems there. id say the higher the better. i used stock sized OEM bearings on my rods. i dunno y u would want bigger bearings. probably for better oil control. ive gone almost the whole race season now w/no problems whatsoever. rev to 9k at the track anywhere from 1-4times a month w/multiple passes.
11:0.1 is very streetable
on one of our cars we were running 13:1 possibly higher on 93+ Sunnco gas. but no point in going that high without sick cams.
in my last car i was running 12:1 tuned with a stock idle, so good luck.
yea i was thinking of building my h22 with a 12.5:1 compression but alot of people told me that is to high for the street. you guys are saying with the right tuning i should be able to run that on 93 octane with no problem? how long would an engine like that last about with only around 10-15 runs a year
[Modified by esp169, 1:14 PM 9/8/2002]
i dunno what the other guys r doin for "tuning". my car is mostly track driven but gets street time too. its untuned as they get. put the motor together, started it up adjusted the idle and timing and done, no detonation. chipped P28 runnin it.
ck279
May 28, 2002 03:18 PM
