94 accord help
Old Feb 26, 2010 | 02:17 PM
ffdrift101's Avatar
Default 94 accord help
i have an 94 accord and i went to the shop to get an alignment .but the guy told me that the frame is bent .would that cause the front wheel to sit back towards the fender .and if so is there an easy way to fix it.also my fuel gauge stop working is the a way to change just the gauge or will i have to change the whole cluster?
Old Feb 26, 2010 | 03:05 PM
PilotOnDubs's Avatar
Default Re: 94 accord help
you can change just the fuel gauge itself...but are you sure thats the problem?
Old Feb 26, 2010 | 05:49 PM
ffdrift101's Avatar
yeah its the gauge i had everything tested
Old Feb 27, 2010 | 04:52 AM
MAD_MIKE's Avatar
MM Gruppe B
Depending on the amount of damage sustained. When you say that the 'front wheel to sit back towards the fender', do you mean the wheel has moved reward and is closer to the door? Or is the wheel cambered excessively? If so which way, also it would help to know which side the wheel is on.
I noticed your SN has 'drift' in it. Is there a story as to how the wheel became relocated? Were you getting 'cricket-lickit-wicked-twisted' and then 'bap'd' the curb? You may have just a damaged control arm, observing the left side to the right side you should be able to notice if the relocated wheels suspension looks different(bent) compared to the correctly aligned side.
A picture is worth a thousand words.
integra dave
Oct 15, 2016 12:48 PM
Nicholas Bailey
May 15, 2016 10:51 PM
76 camaro car
Sep 11, 2011 04:23 AM
integra dave
Jun 13, 2002 07:20 PM
