Jun Integra tire and wheel setup.
Links
http://www.hondatuningmagazine.com/f...e_r/index.html
Rims & Rubber
Advan TCII 17 x 8.5-inch (F), 17x7.5-in. (R)); Advan A048 245/40R-17 (F), 215/45R-17 (R)
Does anyone know the offset on the front and rear?
I want to run a 245/40/R17 in the front but I don't know what offset to use.
Rims & Rubber
I have 2005 civic coupe but its almost identical to the RSX.
I also have the 5 lug swap from RSX type S. I just need to know what offset I can use to fit a 245/40/R17 or 245/45/R17
I haven't taken measurements. but I have looked at tirerack.com to look at tire size measurements and I did look at a tire calculator to see if it would fit. The only problem is I am worried about the offset. I am currently running 17X7.5 +45 offset
With what tires? Does it look like you have room? What tires do you plan on running. Some tires actually fit wider than their specs. What exactly do you plan on doing and for what purpose? How much camber and how low are you?
Bridgestone RE 050 8.8" tread width 245/45/R17
Bridgestone Potenza RE760 Sport 9" tread width 245/45/R17
Fuzion ZRi 8.6" tread width 245/45/R17
current set up 225/45/R17 +45 offset
1.5 drop all around on MeganRacing Coilovers
No Camber
The reasons I am going with these tires I have hook up on Bridgestone.
The purpose of this set up is for the track NASA HPED and DD.
I want to run wider in the front to stop the understeer.
No Camber
Never fails ^
I was feeling all serious and technical after this thread, then I just read about a nasty 2.6L K24a1 build in the allmotor section that got me feelin' even more into it lol... then I come back here and I get a post like that hahahaha! Shoots me right back down to Earth.
Bridgestone RE 050 8.8" thread width 245/45/R17
Bridgestone Potenza RE760 Sport 9" thread width 245/45/R17
Fuzion ZRi 8.6" thread width 245/45/R17
1.5 drop all around
No Camber
1.5 drop all around
No Camber
I already rolled the rear fenders, but I want to stay away from rolling the front fender because I do not want to loose the fender wall guard. I am on MeganRacing Coilovers.
If you want to reduce under steer and fit wider tires just run as much negative camber as possible up front. Chances are you'll max out at -3* without modifying your stock shock towers. Pick up 2 sets of camber bolts for the struts, run them all full negative adjustment and then fine tune with your top hats.
