pg7 ecu- timing for engine?
Old Feb 26, 2010 | 08:39 AM
mitsubishiv5's Avatar
Default pg7 ecu- timing for engine?
im trying to use search but it may just be the way im using keywords to search for my answer...........
Id like to know if running in the pg7 ecu on a sohc mpfi needs a specific timing? more advanced or more retarded, exact degree mark for timing with gun etc. just would like to know any info. would also like best performance out of my zc.
Old Feb 27, 2010 | 07:30 AM
Tyson's Avatar
Default Re: pg7 ecu- timing for engine?
the more advanced you go with the distributor, the more power you get.
http://www.norcalcrx.org/dyno/tyson_1_3.gif
you using this on a DOHC ZC? or SOHC? the PM6 makes more power with the A6/SOHC ZC.
acmoc
Jan 9, 2012 08:45 AM
migizzel
Nov 14, 2005 10:10 AM
CivicRaping
Mar 17, 2005 04:21 PM
sporty240
Apr 25, 2004 12:57 AM
