B16 Tranny Help!!!!!!!!
I just put in a b20 with a b16 trans... got the motor running, runs excellent went to go test drive it... got it through all the gears put it in neutral tried to put it bac in gear but it didnt engage into gear... pushed it home and everything looks right i dont kow whats going on... it has new flywheel, clutch throwout bearing, pilot bearing, and slave it about 3 month old. b4 i bought the trans i took it for a test drive b4 i bought it and it went through all the gears and next the guy had it out for me. ANYONE HAVE ANY IDEA PLEASE HELP
Sounds like your clutch is no longer working properly. When this happened to me, the clutch slave came unbolted from the trans (yikes) and stopped pushing against the clutch fork. Easy fix, though.
Do the gears engage while the engine is turned off?
Fluids is in... shift fork moves... to be honest i think it either the trans is f**ked (which i dont think because one sec it shifts and i put it bac in gear and the trans dosnt not engage) plus it has around 70K on it or the shift linkage... when the car is off and i try to put it in gear dosnt feel like it even tryin to go in gear... any other suggestions
not bleeding out the system right wont keep the car from going into gear when i have a clutch pedal... i didnt have to bleed out b/c i unbolt the whole slave b/c i can still use the same slave... i never open the line so no air got in it
let me just add... with the engine on and off... i can move the shifter like i want to put it in gear but it the tranny doesnt engage... i have type r shift linkage u think that i could be longer or angled different??? hope this help any...
it moves in and out... it also twist left and right... but left and right it moves a hair i dont know how much it suppose to twist never actually took a look at that... but i will check it out tomorrow
