Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wilwood brake pad compounds - Polymatrix, Smart Pad
Old Feb 26, 2010 | 07:34 AM
polska11111's Avatar
Default Wilwood brake pad compounds - Polymatrix, Smart Pad
I was looking for opinions from people that have used the polymatrix or smart pad compound brake pads from wilwood. I use my car for primarily track days and was wondering which compound would suit me best. Anyone have experience or preferences? (I personally do not care if there is a lot of noise or brake dust)
Here is the pad that I would need to use: (7816)
http://wilwood.com/BrakePadsList.aspx?padtype=78
My options are:
CM - Composite Metallic
BP-10
BP-20
BP-30
PolyMatrix A
PolyMatrix B
PolyMatrix E
PolyMatrix H
PolyMatrix Q
Old Feb 26, 2010 | 09:21 AM
JW racing's Avatar
Default Re: Wilwood brake pad compounds - Polymatrix, Smart Pad
I have used poly A,B and C and many other brands to compare.
What does your car weigh,what type of engine is in it,then we can guide you a bit.
The two best pads I have used to date are the Wilwood poly B, and Performance Friction PFC-01.Poly A have too much Bite for most Hondas.
Old Feb 26, 2010 | 10:59 AM
racinjason's Avatar
I have run the B compound as well, however I have found that Hawk HT-10 are easier to modulate.
The dust that comes off the Wilwoods KILLS wheel finish if that matters to you. I ruined the finish on a set of brand new wheels the first time out with those pads and the wet weather.
Old Feb 26, 2010 | 07:49 PM
Well, I have a DB1. (4 door g2 integra). My guess is going to be that it weighs approximately 2600 lbs with me in it? I could be off though. The engine is a b18a1 turbo that puts out roughly 240 whp. I am going to be swapping that out for a b18c1 that will be using the same turbo set up which I doubt makes much of a difference.
Old Feb 26, 2010 | 08:23 PM
slammed_93_hatch's Avatar
I ran the A's and faded them farly easily (H2 car 2300lbs 160whp).
I don't know what I'm doing different as others run the same exact brake setup I do and get constant lock up with the As.
I didn't think they had that good of modulation, but they weren't a lock up once the peddle was touched like others have experenced.
I had some cobalt friction XR2s made up, and have had really good luck with them in testing.
I ran the As with the stock brake plumbing for a EG hatch with a 15/16th MC, and then custom lines with a prop valve, and then with a 1"MC. Fine to modulate, just faded.
BuyBrakes.com
Suspension & Brakes
Jan 3, 2012 09:18 AM
FerioB18
36
Aug 24, 2005 11:43 AM
FitCRX
Jul 6, 2003 06:14 AM
fe519
Dec 12, 2002 11:02 AM
Sam
Nov 27, 2001 04:35 PM
