What's up with this rear trans bracket?
I bought this from someone with some mounts. I'm putting an LS-VTEC in my CRX. It's a B18A block and B16A head with a B16 Y21 transmission.
The holes line up perfectly, however the bolts that thread into the transmission will not fit through the bracket's holes.
Any ideas?
Any ideas?
if i understand you the bolts that fit into the tranny are 2 big to fit into mount bracket
this may sound too simple but um..... get a drill and a drill bit and open them suckers up
the bracket you have is for a cable trans. the hyrdo trans brackets is the same but they have larger diameter holes for the bolts. on my b16 swap i did just as what fenix409 suggested. i drilled them larger. works fine.
Have a friend with a drill press, will have it taken care of
Took it to friend's classic craftsman/sears roebuck drill press. Used scraps to make the bracket sit even, and a clamp to hold it down.
Both holes perfectly bored out in less than 10 minutes
Thanks again.
Thanks again.
AK94GSR
Sep 14, 2010 08:12 AM
90civichbsi
Aug 9, 2006 12:26 PM
Took me an hour to widen the holes on my traction bar that didn't quite line up and that was only 3/8" thick.
