still problems with my crx si gsr swap
so the car used to bogg out when i punched the gas.
the it would go into "limp" or "safe" mode and wouldnt let me 3000rpms.
now the car just wont start..check engine light codes 4 and 9 so i bought a new distributor and the car still doesnt start...i found out there was no fuel going to the motor so i changed the main relay and now fuel runs and everything but car still doesnt start.
later i found out the car has no spark...how can i fix this problem? i try the old distributor and no spark then the new one and still no spark.
and i also tried different ecu's
im frustrated and need some serious help.
You said you tried different distributors right?
Well then your problem should be in the wiring. Since its swapped and idk if u used a jumper harness, i cant tell you what wire colors to look for. Its 2 wires coming off the distributor harness and run to the ecu.
Also if ur ecu doesnt recieve the signal from the vrs as soon as u turn the engine over, then it will not start.
TonyBlaz
12
Mar 22, 2009 06:10 AM
