flash pro vtec change
In changing the vtec cross over point lower in the rpm range, what happens after you are out of the range? Ex. 3000-5800. Are you still producing power after 5800, or staying at the max until you redline? Thank you
The stock VTEC engagement is at 5800, meaning VTEC is from 5800 rpm to redline. When you lower it's engagement point, it just means that VTEC is from the new engagement point (say 3000 rpm). It still lasts all of the way to redline, which is also usually raised.
^he's curious if you're still in vtec beyond the upper window. as in he thinks that 5800, is the end of vtec basically. and the answer is no. beyond 5800 its going to stay in vtec.
well u can put the upper window above 5800, but that would cause valve train damage. you have to remember that you are re-writing the code of the ecu. so once you program it, its going to do the exact that you inputed.
how would raising the vtec crossover cause valvetrain damage?
^the motor isnt designed to run above 6k on low profile. thats why people who have brains should know never to beat on a cold engine. i heard different opinions on what causes it on hondas, but the most common i've heard is something with the lost motion assembly and im guessing wat happens is when the motor is rev'd so high on low profile, the valves come up too fast and the lo profile cam isnt aggressive enough to catch the retainer in time and hi profile cam is aggressive enough to catch the valves coming up before any damage is caused.
since i've never head that raising the vtec crossover point damages the motor before, i figured i'd try to find out if there's any truth to it. are you never curious about anything?
I think on some of hondata's tuning videos they say don't set the vtec too low because you may lose oil pressure and not above 7000 or 7500 because it may cause cam lobe damage but I haven't watched them in awhile.
