HELP!!!!!!
Old Feb 24, 2010 | 09:44 PM
Migs87's Avatar
Icon2 HELP!!!!!!
Ok so this is how things are right now, My 89 CRX Dx with a B18B was stolen i recovered it with the Motor and Tranny Still in it. All the thief's took was some parts Including my PR4 ecu and the Dizzy, well i recently got a PR4 and a TD23u dizzy i installed the parts on Tuesday and turned it on, But the CEL came on so i let the car warm up after it warmed up i Tried Reving it but it Wont go More than 3100 Rpm, i changed the injectors and yet it still does the same thing, so im not sure but the red light on the ecu blinks and it seems to be giving 2 codes 4, and 16 what can i do?
Old Feb 24, 2010 | 09:47 PM
BiG ChOr!Zo's Avatar
Default Re: HELP!!!!!!
http://ef-honda.com/ben/ECUcodes.php
Old Feb 24, 2010 | 09:55 PM
Migs87's Avatar
yeah thanks for the site i appreciate it. i just don't know what to do in order to fix the problem i already switched the injectors.
Old Feb 24, 2010 | 10:01 PM
im not familiar with 4 but 16 usually will go away by resetting the ecu,changing main relay,fuel filter and using fuel injector cleaner...!!!
Old Feb 24, 2010 | 10:21 PM
Migs87's Avatar
Oh ok thanks alot bro. ill have to try it ASAP tomorrow morning i want my Rex running good again
Old Feb 25, 2010 | 09:01 AM
EFRue57's Avatar
code 4 is crankshaft position sensor. that code will be thrown if you have a bad distributor. the dizzy you got is bad.
Old Feb 25, 2010 | 09:04 AM
Migs87's Avatar
aaah that blow's,and i just bought it off someone here on h-t. thanks, i would have to buy new internals for it then?
Old Feb 25, 2010 | 09:32 AM
hatchet_honda's Avatar
you cant buy internals...only the igniter, rotor, coil etc. can be replaced the crank sensor is part of the dizzy. buy a NEW dizzy
Old Feb 25, 2010 | 09:43 AM
blasterman87's Avatar
yup, new dizzy time.. buy one from ebay seller distributor king. they are cheap and have warranty
Old Feb 25, 2010 | 02:24 PM
Migs87's Avatar
what if i change the Ignition Coil?
Old Feb 25, 2010 | 04:51 PM
jdmrexy90's Avatar
what would a constant red l.e.d. light, no blinks mean for a dx crx?
Old Feb 25, 2010 | 04:59 PM
jakop92's Avatar
Bad ecu or bad ground. Next time don't thread jack and do some research before you post a question.
Old Feb 25, 2010 | 05:13 PM
jdmrexy90's Avatar
uh huh think yu smart one! its called not wasting a thread nd posting on a similar thread. i dnt need 10 posts of explanations just my 1 post which yu answered. faster to ask then research
Old Feb 25, 2010 | 07:17 PM
Migs87's Avatar
ok ok i have another question my Dizzy is obdo and my motor is OBDII now i know the crank position sensor is on the block near the oil pump on the OBDII and what about the OBD0 dizzy since the OBDI has it in the Dizzy lol help will be wonderful again i already got rid of the cel code 16 thanks ChOr!Zo and thank you EFRue57, hatchet_honda, blasterman87 forthe help also
splatter_punk
May 6, 2012 05:13 PM
WrongWD
16
Jul 1, 2007 11:13 PM
fonkernuckle
May 2, 2004 10:38 AM
D_TY3
May 2, 2004 08:51 AM
HatchBox
Jun 16, 2002 08:20 PM
