Are b series auto and manual flywheels same?
Old Feb 24, 2010 | 08:26 PM
turbo_d's Avatar
Default Are b series auto and manual flywheels same?
Ok, I have a question for you guys. Is a flywheel from an automatic b18 gonna be the same as a flywheel off of a 5 speed b18?? Thanks, david
Old Feb 24, 2010 | 08:39 PM
zsoccerdude17's Avatar
Default Re: Are b series auto and manual flywheels same?
In automatics they are reffered to as a flexplate not a flywheel and are usually much thinner and light weight as well as lighter duty than a flywheel.
Old Feb 24, 2010 | 08:41 PM
placid888's Avatar
no, it is not the same, automatic is flexplate and manual is flywheel
Old Feb 24, 2010 | 08:43 PM
Deetz's Avatar
Crazy Honda Guy
Correct, auto's use a flex plate, which can not be used with a clutch. All 1990-2001 b series flywheels are the same with the exception of the Type R model which is a couple lbs lighter
SkylerTheG
Transmission & Drivetrain
Jul 20, 2013 03:36 PM
Bruce Banner
Feb 9, 2007 07:45 PM
SOHC_Brian
Aug 7, 2004 01:05 PM
lunarcry
Jan 9, 2003 11:53 PM
