k20 k24 parts *LOOK* blocks,rocker assembly,pans,covers,vtec,cranks,
I have all these parts that are taking up too much room in my shop so time to start selling off. Please look down through this list. less talk more pics pm me any questions you have. All items are priced shipped to U.S but you will need to pay paypal fees. peanutscrx@yahoo.com
PRB intake manifold complete w/rail and injectors and full types throttle body with all sensors $250 for the complete unit or $200 for just the type s tb
k20a2 crank pulley w/bolt missing keyway $100
full set of k20a2 pistons/rods with around 50k miles on the clock $100
x3 k24 ppa pistons/rods $30
x2 k20a2 fuel rail w/injectors 50each
x5 oil pump chains $20each
x3 k24 timing chains $40each
x3 k20 timing chains $40each
k20 NEW arp headstuds $85
x5 vtec spool assemblys $50each
x3 oil psi sensors $20each
x5 tensioners $25each
x2 k20a2 timing covers $50each
x2 k24 oil pans $85each
x2 k20 oil pans $85each
k20 oil squirters $30
x2 thermostat housings $30each
prb intake manifold with rail and injectors $75
tsx intake manifold with rail,injectors, and map sensor $100
x5 k20a2/z1 cranks $125each
x3 k20a3/k24 throttle bodies w/sensors $50each
x2 valve covers $50each
x3 oil coolers $35each
3 k20a2 rocker assembly setups. 2 without cams and one complete with cams/gear.
$275each for the ones without cams
$350 for the assembly with cams/gear
Also have a bunch of extra parts just misc stuff let me know what you may need I have tons.
for some K
