Honda S2000 Honda S2000
Couple strange issues with 2003 S2K
Old Feb 24, 2010 | 05:24 PM
Sean @ ESG's Avatar
Default Couple strange issues with 2003 S2K
The first issue deals with the clutch fluid. There is no leak anywhere, but about twice a month I need to fill the reservoir up with fluid because I get a dead clutch pedal. There is no fluid under the car where I park, no drip/leak in the bay, under the car, or inside by the firewall. Any ideas? I even had a trusted shop owner look at it, and he could find no leak.
The second is a clunk/popping noise coming from the under side of the car. At first I thought it was a broken bushing or something, because I noticed more when the car was flexed backing out of the driveway, but I've also heard it when turning. As if it had something to do with the steering. I lifted the car up, poked around for loose parts, but found nothing. And all bushings are in-tact. Turning the wheel with the car jacked up it made no noise at all. But when on the ground, it does.
93,000 miles on the car
Thanks for any help/suggestions
Old Feb 24, 2010 | 05:57 PM
Black S2K's Avatar
Default Re: Couple strange issues with 2003 S2K
i had that clutch issue its ur master clutch cylinder it leaks on the inside u cant see it because it drips right ontop of the dead peddle so its hard to catch. at least that's what the problem was with mine the seals inside the cylinder tend to wear out around that mile mark i was at about 95k when i noticed this
Old Feb 24, 2010 | 09:27 PM
bodiez's Avatar
Hit the floor!
Not an S2K guy, just a lurker but I would say that could be an axle sir. Check for play at the CV joints.
Old Feb 25, 2010 | 04:40 AM
Zaakro's Avatar
sorry man car is rear wheel drive so it more than likely isn't this.
does your clutch pedal make a noise when you push it when it is cold out side?
its what black s2k said, the clutch is leaking inside the car. this is a really common problem on these cars
Old Feb 25, 2010 | 10:17 AM
Deano_d's Avatar
Make sure both axle nuts are at 230ft/lbs tq. Loose ones can cause a clunk.
Old Feb 25, 2010 | 10:30 AM
honeybadger's Avatar
My car also had the occasional pop while turning, going over uneven ground, or hard braking. I never did figure out what it was but nothing ever went wrong related to the sound ... hope that is encouraging!
Old Feb 25, 2010 | 10:54 AM
shift_oversteer's Avatar
New User
Is your car lowered? That could change a few things.
Old Feb 25, 2010 | 12:34 PM
.john.'s Avatar
You do realize that s2ks have two rear axles, both have cv joinst on either end. The driveshaft also has 2 cv joints on it as well. That clunking noise can be a number of things, I had one customer bring his car in for the same noise and turned out to be a loose bracket for the soft top that was moving when the body flexed. But it is also common for the axle nut thing as well as loose shock parts or even something small like missing a brake pad retaining clip in the caliper causing the pad to shift forward and back under braking making a clunking sound.
Old Feb 25, 2010 | 10:25 PM
JDMF22B's Avatar
^^^ There is a TSB about rattle/click/clunk noises on soft-tops on uneven surfaces/harsh roads. Probably not related but just to prove john's point.
Old Feb 26, 2010 | 04:36 AM
White Smoke's Avatar
i my honda
Global Mod
CV's on the S's DO POP sometimes. First thing to check is the axle nut though, that was a common problem.
Also, you def have a leak and more then likely it is your master as Black S2K said.
Old Feb 26, 2010 | 07:22 PM
Sean @ ESG's Avatar
Great! Thanks for the responses guys. I'll def. check out the master cylinder seals!
As far as the clunking. The sound is coming from the front/mid, right under-side of the car. I'm pretty sure it's not the axles because the clunk sometimes happens when the car is at a stand still, just turning the wheel. No sound is heard from the rear either.
My first impression was a loose sway bar, or corroded bushing, but I couldn't see anything, and everything on both sides is tight.
I'll check the axles out in the rear just to be sure, but won't be surprised if I don't find anything.
Thanks again.
Old Feb 28, 2010 | 03:46 AM
conker's Avatar
Fluid will likely be under the carpet. As for the clunk, LCA bushings can take a beating,
http://www.s2ki.com/forums/index.php...ic=165828&st=0
also check your welds to the frame.
http://www.s2ki.com/forums/index.php...pic=50244&st=0
Old Feb 28, 2010 | 09:28 AM
Sean @ ESG's Avatar
Cool, thanks for the links. I'll check it out again this week.
Old Mar 20, 2010 | 01:33 PM
Sean @ ESG's Avatar
Bump.
I looked underneath the car for over an hour this week and couldn't find one thing that looked odd. No scrapes, marks, torn bushings, loose parts, missing bolts, cracks, or anything. Took off the air box to get a better look at the steering rack, and found nothing. Couldn't find anything wrong with the steering column either.
I also could not recreate the sound when the car was in the air either. Could it be that there is something wrong with the frame? It's driving me crazy. The sound is SO loud, and it's frustrating me that the issue is not as apparent as it should be
Old Mar 21, 2010 | 08:02 PM
b18a1ef9's Avatar
i have the same clunk. except i believe its coming from my brakes. in the morning when i take the car out. i hit the brakes going down my driveway and i hear the clunk when i hit the brakes. maybe you can try that, you never know. good luck.
Old Jul 17, 2010 | 12:53 PM
Sean @ ESG's Avatar
Update on that popping sound - seemed to be a ball joint on the front right side that loosened itself. But the cotter pin was still in...strange. but that seemed to fix that.
I have a new thread with a NEW sound for those interested in helping
Old Jul 19, 2010 | 02:01 PM
ap1padawan's Avatar
i get the same clunk sound everytime i back out from my driveway
i hear the sound whether i roll back in neutral or when i put it in reverse
Old Jul 21, 2010 | 08:40 AM
ReddotsS2K's Avatar
I think its the axles nuts, and it sounds more like a click
Old Jul 23, 2010 | 06:04 PM
Sean @ ESG's Avatar
See post #16 if you're having the same issue. I found it.
Old Jul 29, 2010 | 08:58 AM
Jspd's Avatar
I agree with some of the statements above. The axle nuts need to be checked and torqued to spec. Also the CV cups begin to pit and may need to be swapped if you are feeling any vibration when accelerating.
The leaking as stated above is likely your master cylinder. Crawl under your dash and feel around where the cylinder meets the firewall. You will most likely feel moisture. The same thing happened to mine Its around 115 dollars to purchase a new master cylinder, and the install is extremely easy.
gnarlycs
11
Jun 10, 2012 05:19 PM
curtie94
Sep 9, 2011 05:30 PM
TyPe_R_GuY
Apr 4, 2004 12:23 AM
Finest
Jan 6, 2003 08:22 AM
