Crower Cam Timing
Old Feb 24, 2010 | 03:53 PM
K20EF8Dx's Avatar
Default Crower Cam Timing
Ok my buddy has a B16a and has upgraded to Crower 63402-2 cams and full valve train. we dont have access to any degreeing kits and want to install these correctly. He is also running AEM cam gears that can help. any links or knowledge is greatly appreciated!
Thanks!
Old Feb 24, 2010 | 06:45 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Crower Cam Timing
If you can tell me what the cam centerlines are or find out what they are by contacting Crower, I can help you.
Old Feb 24, 2010 | 06:53 PM
K20EF8Dx's Avatar
i will email them and find out.
so far all we know from their site is their durations
Advertised Duration
Int- 311 mid
Exh-308 mid
Duration @ .050"
Int- 255 mid
Exh-248 mid
Gross Lift w/1.55
Int- 466 mid
Exh-466 mid
Old Feb 27, 2010 | 07:29 PM
K20EF8Dx's Avatar
Bump.... also still awaiting on crowers response to my email!?!?
Old Mar 1, 2010 | 10:44 AM
K20EF8Dx's Avatar
http://www.crower.com/misc/cam_spec/...02-2&x=30&y=12
Part Number/Work Order Number 63402-2
Engine Application B16A/B18C/B17A
Grind Number
ADVERTISED CAMSHAFT SPECIFICATIONS:
INTAKE: Duration: 311º Lift: .467 Clearance Hot: .006
EXHAUST: Duration: 308º Lift: .467 Clearance Hot: .008
The specifications listed above are based on a rockerarm ratio of 1.55 IN
1.55 EX
RECOMMENDED VALVE SPRING INFORMATION:
Part # 68185 Single Dual X Triple
Approximate spring pressure: valve closed: 050/055 LBS.
valve open: 185/190 LBS.
31.0
BTDC 19.0
ATDC
ABDC
45.0 49.0
BBDC
The information below is for degreeing cam only. Correct only at .050" tappet lift.
INTAKE Opens: 31.0 BTDC
Closes: 45.0 ABDC
EXHAUST Opens: 49.0 BBDC
Closes: 19.0 ATDC
LOBE SEPERATION 101º
Duration at .050" Intake: 255
Exhaust: 248
LOBE LIFT Intake: .301
Exhaust: .301
If using "Lobe Center" method of degreeing, cam should be installed on an intake centerline of: 97º
NOTES:
B-1545 EXHAUST
SB2 HEAD AND BLOCK CAM CORE 50 MM
CYL 1,7,2,8, ON A 110 LC.
CYL 3,4,5,6, ON A 108 LC.
Cams damaged by excessive spring pressure, over shimming, valve train bind or retainers contacting the guides are void from warranty. Refer to the "Important Camshaft and Lift Information" booklet included with each new Crower camshaft to avoid any break-in problems.
harhoosh
Feb 10, 2012 10:20 PM
konad
Mar 5, 2010 05:49 AM
y-49
Apr 6, 2008 02:15 PM
robtec
Sep 21, 2003 05:45 PM
Mover
Nov 19, 2002 06:40 PM
