NEED HELP! TRYING TO SWAP OUT MY 88 CRX TWO POINT FOR A 92 CIVIC FOUR POINT
Old Feb 24, 2010 | 10:48 AM
wunest's Avatar
Default NEED HELP! TRYING TO SWAP OUT MY 88 CRX TWO POINT FOR A 92 CIVIC FOUR POINT
Just wondering if there is a place to just buy a harness that connects to my ecu (obd0) for the conversion and if so what kind of harness would it be.
88 crx two point trying to convert to a 92 four point
thanks
Old Feb 24, 2010 | 10:57 AM
D16SiHatch's Avatar
Default Re: NEED HELP! TRYING TO SWAP OUT MY 88 CRX TWO POINT FOR A 92 CIVIC FOUR POINT
what you're trying to do is called a dpfi to mpfi conversion.
here's a writeup on how to do it
http://hondaswap.com/swap-articles/d...writeup-49557/
if you want to have someone make a harness for you then go here.
http://rywire.com/store/8891-crxcivi...cc75efa82d075e
Old Feb 24, 2010 | 10:59 AM
Staypuff578's Avatar
What motor are you swapping in?
You will need a jumper harness for obd0-obd1. You can find those at http://rywire.com or PM me i have one.
Look in the FAQ at the top of this forum as there is PLENTY of info on this swap.
Edit: D16sihatch covered pretty much all of it.
Old Feb 24, 2010 | 12:23 PM
wunest's Avatar
TO STAYPUFF578
i already have a crx si 88. it came with a d16 motor.
Old Feb 24, 2010 | 12:26 PM
wunest's Avatar
THANKS GUYS FOR THE ASSISTANCE
Old Feb 24, 2010 | 12:30 PM
Jockone's Avatar
Originally Posted by wunest
TO STAYPUFF578
If you have an Si then it is MPFI so why do you want to change from DPFI an Si does noy have DPFI
Old Feb 24, 2010 | 02:10 PM
lunalink's Avatar
TO STAYPUFF578
lol. its not an si
they probably just put the sticker on it and sold it to you.
well as they stated above follow the links they provided you and start doing some work.
experience is the key
Crx_Daniel
Feb 6, 2013 01:01 PM
wunest
Feb 24, 2010 01:09 PM
93formula
Jun 10, 2005 12:18 AM
OneSikEp3
May 30, 2005 06:10 PM
